Hatchback Rear Winshield Wiper Removal - Honda-Tech
Old 04-01-2009, 10:02 AM   #1
9.3.S.I.L.U.D.E.'s Avatar
Default Hatchback Rear Winshield Wiper Removal
hey wats up guys
im having trouble removing my rear winshield wiper
from a 95 hatchback civic can somebody tell me how to take it off
thanks
9.3.S.I.L.U.D.E. is offline   Reply With Quote
Old 04-01-2009, 10:04 AM   #2
kp
kp's Avatar
Default Re: Hatchback Rear Winshield Wiper Removal
Theres a plastic cap at the end that pops off. Under the cap is a nut that holds the arm to the motors shaft. Undo the nut. I've done this before and had to torch the nut to get it off because of the rust. Use some penetrating fluid and the proper socket/wrench to get it undone.
kp is offline   Reply With Quote
Old 04-01-2009, 10:08 AM   #3
oh ok so i have to take everything apart..
so its way different than the front winshield wipers
Old 04-01-2009, 10:09 AM   #4
instructor74's Avatar
pop the plastic cover off the wiper arm remove the nut holding the wirper arm to the shaft wiggel and pry the arm off the shaft. If you are removing the whole unit from the car. On the inside remove the screws from the clam shell covering the wiper motor pop the shell appart. remove the nut that holds the plug/ finger hook on the left of the window. Remove the large nut from under the wiper arm on the outside of the window the motor assy should now pull out
instructor74 is offline   Reply With Quote
Old 04-01-2009, 10:13 AM   #5
alright thanks i got the idea
im just going to change the wiper blades
Old 04-01-2009, 10:18 AM   #6
So you're just changing the blade, not actually removing the whole assembly. Funny.
kpaton is offline   Reply With Quote
Old 04-01-2009, 10:33 AM   #7
deadazleep's Avatar
yeah u dont take the arm off to change the blade
deadazleep is offline   Reply With Quote
Old 04-01-2009, 10:41 AM   #8
Quote:
I think everyone else assumed he was trying to delete the rear wiper entirely, not just change the blade.
Old 04-01-2009, 10:43 AM   #9
kp
kp's Avatar
I just figured changing wiper blades wouldn't be the topic of a thread. I assumed it was a delete question.
FS: Si front lca's, front strut bar, hatch stock wing and integra rear wiper motor 714DC4 For Sale 8 03-17-2009 08:36 AM
winshield wippers Sergezy Honda Civic / Del Sol (1992 - 2000) 4 12-20-2006 04:06 PM
WTB-oem hood and winshield ruckussss For Sale 2 03-06-2005 12:32 PM
winshield wiper marks goodOLdayz Honda Civic / Del Sol (1992 - 2000) 7 04-15-2004 09:39 AM
integra winshield wiper removed? ipath22 Acura Integra 2 09-26-2002 11:21 AM
Tags
02, 95civichatchbackwiperremoveal, arm, change, civic, delete, diy, hatchback, honda, insight, rear, removal, remove, si, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
