harmonic balancer wobbling? - Honda-Tech
Old 04-18-2011, 01:54 PM   #1
hotdoggies's Avatar
Default harmonic balancer wobbling?
So it was a warm day today and i turn my a/c on to cool down. The compressor i noticed started to make a screeching sound so i turn it off after about 5 min. Upon arriving at my destination I here a puffing/ticking noise coming from the engine. From what i can tell the Crank pulley is wobbling pretty bad. Can this be caused from the compressor going bad and putting to much stress on the pulley? It is really worrying me that it is the harmonic balancer pulley...
hotdoggies is offline   Reply With Quote
Old 04-18-2011, 04:54 PM   #2
Resident Gearhead
BryanM.'s Avatar
Default Re: harmonic balancer wobbling?
Check if the crank pulley bolt is loose.
Keep using it like that and the key ways of the crank and crank pulley and the key itself could get screwed up.
BryanM. is offline   Reply With Quote
Old 04-19-2011, 04:39 AM   #3
There is NO WAY your A/C compressor could put enough strain on your crank pulley to damage it. Why? Even if your compressor seized and the clutch held, the belt would slip, melt, and then break. It would feel like all hell had broken loose for a second, and then the belt would break with a loud bang, you would feel like everything was OK.
The harmonic balancer is bolted directly to the crankshaft with a key, tightened with a quite large bolt to ~160 ft lbs. It takes about 300 ft lbs to break the bolt loose, and either the harmonic balancer has to be counterheld, or the flywheel does. (Or the engine could be hydrolocked, I suppose.)
If your harmonic balancer is wobbling, something went seriously wrong and you should probably investigate.
Sonia's Driver is offline   Reply With Quote
Old 04-19-2011, 05:28 AM   #4
I just had the same thing happen to me on my 93 del Sol.
It turned out that the key that holds the main crank pulley in place broke and sheared the tines inside the crank pulley. It happened just when I turned on my AC too. How about that. I recently had work done and replaced the main crank seals and apparently they reused the old key when they replaced the pulley. The cure was buying a new crank pulley and new key. Also there was a small nick on the end of the crank but a little JB weld on that spot took care of that. The pulley cost about $160 (go OEM). The labor involves messing with the main crank nut.
delsolintegra is offline   Reply With Quote
Old 04-19-2011, 06:13 AM   #5
Sounds like a loose or broken crank pulley bolt,you need to check it out ASAP.
Jockone is offline   Reply With Quote
Old 04-19-2011, 07:11 AM   #6
Icon2 Re: harmonic balancer wobbling?
That sounds really fishy.
Can you imagine the force necessary to shear the key in the harmonic balancer? What could put that much force on the pulley?
I bet that the shop that removed your harmonic balancer didn't torque the bolt properly when they reinstalled it. IIRC, it's supposed to be torqued to 150 ft lbs. If they only did it wrench tight, the bolt could have backed off under load, and then the balancer would have started to round the edge of the crankshaft and the key and its splines.
... That would also explain the wobbling harmonic balancer that the OP reported.
OP - did you have any work done on your engine recently? Can you check the bolt on the pulley and see if it's loose?
Old 04-19-2011, 09:39 AM   #7
Well the shop that did the work was a honda shop that I used before and the first thing they checked was that the bolt was tight. It was still tight even after the pulley let go. We talked about it and he said he only saw this happen a few times before after being in to hundreds of cars. I think the lesson learned is always use a new key in the pulley. Like when working on a boat always use a new shear pin after doing propeller work.
Old 04-24-2011, 05:39 PM   #8
hotdoggies's Avatar
Im worried about Bearing damage from a unbalanced crank. As far as the crank, the passage on the snout still exist jus a little scarred.....I drove it maybe 30 miles likethis. So im thinkin bearing damage would be minimal.
Old 04-24-2011, 05:41 PM   #9
hotdoggies's Avatar
I have pulled it off at the Honda Dealership and it scared the end of the crank. Have done no engine work as of late. The inside part of the Harmonic Balncer was completely stripped. Im debating on a new engine or Trying to fix the current engine.,
Old 09-07-2015, 04:39 PM   #10
Just to revive an old thread (that i found via google...)
I just did one of these (97 Odyessy) and found that the bolt was super-loose.
Like probably not more than finger tight or even backed out some. (used impact and if flew off..)
It looks to me like there used to be some splines in there, but not really anymore, see the pics. Anyhow, I'm going to put it back together and hammer it tight with loctite red, and hope it'll be good. The woodruff key seems OK.
Just in case anyone else wanted to know what it looks like!
http://i.imgur.com/uoH717g.jpg
http://i.imgur.com/tBoq9GU.jpg
~scirocco
scirocco is offline   Reply With Quote
Old 09-07-2015, 05:02 PM   #11
And further (looks like there may be a question in here...)
When trying to re-assemble, it looks an awful lot like the crank snout has "shrunk" back into the motor (?!).
I can't see how this is possible, since it looks like maybe 5mm (or 3/8"?) of the harmonic balancer does NOT fit over the pulley, and the key is clearly too long.
Yes, i've tried 'tapping' it to seat, but if you see my last post, there is really very little crank-snout sticking out.
Has anyone seen this? I'm reluctant to just trim the key and bolt it together....
Also, the replacement balancer is identical to the one from the motor, and there does not seem to be evidence of the key gouging the back of the crank bolt.
Ideas anyone? TIA!
~scirocco
with the balancer and key on/in as far as they will go:
http://i.imgur.com/R0xiUVA.jpg
AC Compressor Mystery Crobran Honda Civic / Del Sol (1992 - 2000) 0 02-09-2017 01:37 PM
WTB: D16A Harmonic Balancer / Crank Pulley tWixT Want to Buy 2 09-07-2016 11:35 AM
Harmonic Balancer colecooper Honda Accord (1990 - 2002) 1 02-16-2016 03:36 PM
stock crank pulley or aftermarket??? horn12007 All Motor / Naturally Aspirated 3 08-22-2010 08:06 PM
why is lightened crank pulley bad but not lightened flywheel? h22aBB4 Honda Prelude 13 12-14-2006 02:47 PM
Tags
97, balancer, ballancer, civic, crank, del, harmonic, honda, integra, key, loose, shaft, si, sol, wobble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
