Hard to start after fuel up - Honda-Tech
Old 09-29-2011, 09:18 PM   #1
mycarbonhatch's Avatar
Default Hard to start after fuel up
I have this issue when fueling up and only on a fill up or putting gas in. My d16y8 full GReddy turbo kit and SPEED FACTORY Tune idles at 200 or maybe 300 rpms and wants to die. Hold the throttle at 2k then let off the throttle and it goes away after 30 seconds to a minute and idles at 800.. no engine light "cel". What would cause this?
mycarbonhatch is offline   Reply With Quote
Old 09-29-2011, 10:11 PM   #2
Linked's Avatar
Default Re: Hard to start after fuel up
will it happen to the engine at normal operating temp after you fill up?
Linked is offline   Reply With Quote
Old 09-30-2011, 11:58 AM   #3
It only happens when I fill up never any other time when I start It up. And yes the car is warm at normal temp when I fill up
Old 09-30-2011, 01:11 PM   #4
strategy400's Avatar
Likely something to do with the evap system. Do you smell gas after? Could be getting flooded.
strategy400 is offline   Reply With Quote
Old 09-30-2011, 01:14 PM   #5
Ok so would that be a charcoal canister or something like that.. im new to the Honda world. This is my daily driver just trying to fix the little bugs. Could one of the lines for the evap be clogged or where would I even start with the evap system?
Old 09-30-2011, 07:02 PM   #6
Yes there is a charcoal canister, the pupose of which is to absorb fuel vapor (evap) so it can be drawn into the manifold later and burned. There are some valves that control the fuel vapor going into the canister from the fuel tank. One you may want to look at is the Onboard Refueling Vapor Recovery (ORVR) which is present on 99-00 civics. It's valve opens when refueling. You may be getting liquid into the canister somehow? Maybe the turbo is overwhelming the evap valves and drawing fuel through the system. Try not filling up all the way and see if symptoms persist. PM me for more detailed info.
Old 10-01-2011, 02:13 PM   #7
i have the same problem on my eg hatch w/ stock d15.I pump gas and cant start it for a couple of minutes.
sohcpoweredeg is offline   Reply With Quote
low idle cold start high idle when warm 2000blksi Hybrid / Engine Swaps 1 05-19-2011 03:22 PM
wont idle/rough idle on cold start 1fast4door93 Honda Civic / Del Sol (1992 - 2000) 2 04-03-2011 07:26 PM
Bog/misfire above 30% throttle after running 10+ min 01 LudeDude Honda Prelude 3 02-09-2008 02:34 PM
idle problem tat2oed Acura Integra Type-R 10 09-12-2005 04:14 PM
Mark : Drama continued... GSRwBOOST Forced Induction 15 01-10-2002 12:19 PM
Tags
civic, filling, gas, hard, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
