Hard to start after fuel up
Old 07-18-2011, 03:08 PM
burfy's Avatar
Default Hard to start after fuel up
Hey guys, got a strange problem. Whenever I fuel the car up, it cranks a lot and usually I have to have my throttle wide open. After that it runs like crap for 30-45 seconds. Just recently it's been throwing a P0132 code. Every start up after that is flawless and there's no issues with the performance of the car. It's a 99 with a d16y8, 10k on a stock cat. Thanks in advance!
Old 07-18-2011, 04:14 PM
motegicivic's Avatar
Default Re: Hard to start after fuel up
Well it is an Oxygen sensor code, I would check that first, but I think there are 2 so see which one it is.
A bad Oxygen sensor can cause running problems.
Old 07-22-2011, 01:24 PM
burfy's Avatar
The problem only occurs when I fuel up though. The code will clear with my scan tool right after. And the car drives and starts normally until I fuel up again
Old 07-22-2011, 02:05 PM
strategy400's Avatar
Is it only after a gas stop or does it do it after running into the liquor store too?
Old 07-22-2011, 02:24 PM
Former User's Avatar
The code is for the primary O2 sensor. Fix the CEL code and then go from there.
Old 07-22-2011, 07:53 PM
burfy's Avatar
It only happens when I fuel up the car, and it only becomes active the first start after that. The code clears and doesn't return until the next fuel up
Old 07-22-2011, 08:04 PM
I stand by my recommendation.
Old 07-22-2011, 08:15 PM
burfy's Avatar
Would you recommend to r+r the sensor with a known good one?
I was leaning more towards a fault with the emissions system, like the evap? The car feels like it runs rich after I fuel up and the only way it'll run well is if I hold the throttle. If I release the throttle it chugs and sometimes stalls.
Old 07-22-2011, 08:24 PM
Old 07-22-2011, 08:41 PM
Mine used to do this too, to the point where I'd leave it running during fueling. It happened in warm weather. No CEL.
Then my headgasket let go so I swapped in my spare long block (same exact model engine and just transferred over all the ancilliaries).
The problem disappeared.
How many miles on your engine?
Old 07-23-2011, 08:24 AM
sscivicsi's Avatar
when you fill it up, do you top it off? Or just let the pump stop and then stop fueling?
topping off might be evap issue
Old 07-24-2011, 06:39 PM
burfy's Avatar
Fueled up today, had to hold throttle to maintain engine but didn't get a CEL this time. There's supposedly 98k km on the engine (body has 383k km) I usually round up to the nearest dollar after it clicks, so nothing excessive - less than .5 L
Old 07-26-2011, 05:20 PM
burfy's Avatar
bump
O2 sensor checked out
Old 11-13-2011, 08:48 AM
mycarbonhatch's Avatar
Same problem but never have thrown a CEL. Let me know if you find out what is causing it. Evap system maybe but, I have no clue where to start. Any help please.
Old 11-16-2011, 07:53 AM
burfy's Avatar
I've found it's much worse after a long drive or when it's hot. If I can fill up before the temp gauge reaches the first line it only takes 2-4 seconds to get started and the poor running/stumbling/stalling doesn't take as long to clear up. It's as if the fuel in the lines and rail aerates when the cap is opened or when the fuel is being poured in. Is there a check valve in the fuel system?
hondaboy9506
09-24-2010 10:20 AM
phelps38
07-16-2007 06:48 AM
str8JDMteggy
09-29-2006 08:27 AM
Steemo
05-14-2005 12:01 PM
OBDI JEDI
05-07-2003 05:06 PM
Quick Reply: Hard to start after fuel up
