98 civic ex wont stay running...once running wont go over 20
Old 08-03-2012, 06:56 PM
otgarza's Avatar
Default 98 civic ex wont stay running...once running wont go over 20
i diagnosed one of my buddies car last week and i was getting intermittent spark at the wires. so we went ahead and replaced the plugs since it was overdue and tried a new rotor. nothing. so i tested again and i was gettin intermittent spark at the distributor cap to the wire. we got all new wires and cap. it turned on 4-5 times and stayed running. we left runnin for half an hour and it was good. as soon as we turned it off and tried again it wouldnt turn on. once we got it on again we drove it and it wouldnt go over 20. what should i diagnose next? switch? igniter? coil?
Old 08-04-2012, 09:48 AM
otgarza's Avatar
Default Re: 98 civic ex wont stay running...once running wont go over 20
ive done some research and it seems this could be a coil problem. any way to test it? the switch could also be a possibilty what do you guys think?
Old 08-04-2012, 09:50 AM
Former User's Avatar
See diagram in FAQs sticky.
Also take ICM to AutoZone for free testing.
Old 08-04-2012, 10:06 AM
otgarza's Avatar
alrite ill have a look thanks
Old 08-04-2012, 09:00 PM
otgarza's Avatar
tested everything from the plug wires all the way thru the cap and then the coil and icm. coil wasnt givin me any spark so i checked to see if the icm was giving the coil power and it wasnt. removed icm took it to two autozones and it failed a total of 6 times. getting a replacement soon and i will post the results thanks for pointing me towards the diagrams. they really helped out when testing the power to the icm and coil.
Old 08-07-2012, 09:05 PM
otgarza's Avatar
replaced icm on monday and the car starts fine now thanks for the help. the fluctuating tachometer was a great sign that the icm was on its way out. i was told it was doin that intermittentley for the past 2-3 months.
joemommaaa
02-20-2011 06:01 PM
drtile
01-02-2008 03:17 PM
TehMan
02-17-2006 11:18 AM
Yambor
07-30-2004 06:55 AM
Quick Reply: 98 civic ex wont stay running...once running wont go over 20
