Had a wierd problem tonight....any help??
Old 04-20-2002, 09:26 PM
Petah's Avatar
Default Had a wierd problem tonight....any help??
Tonight, i was at school and the car had been parked for probaly 6 hours. It was a cold night out....maybe -3C. Anyways, i come out and started the car....no problem. Let it warmed up for about 2 min and started to drive. When i turned on my headlights, i noticed that the headlights didn't come on immediately. There was a 2 sec delay and the lights came on. Didn't think much of it, i started to drive. Signaled right to make a right turn, i hear the flasher click, click, click like normal but when i looked at my dash, the green signal indicator wasn't coming on!!! WTF?? So i sat there for like 10 clicks and boom...it comes on. Now thinking i could have a problem, i tried signaling left......and the same thing. I hear clicking....but no green indicator on my dash!! 10 clicks later, it comes on and everything proceeds to work fine for the rest of the way home. Tried tunning the headlights on and off and now, the light comes on normally....no delay. Anyone had a similar problem with their car??
I recently replaced a JDM SIR cluster and the main relay...could these parts be deffective?? But i can't see how the cluster can be tied to my headlights....hummm.....an thoughts? Thanks.
Old 04-21-2002, 12:03 AM
New User
samdawgsol's Avatar
Default Re: Had a wierd problem tonight....any help?? (eg-six)
you might not have a good connection in the relays for hte cluster, try reconnecting it. My left turn signal has had about a 5 sec delay somtimes when it was cold out.
Hopefully its not a wiring problem, check the fuse for them too and see how it looks.
[Modified by samdawgsol, 3:04 AM 4/21/2002]
Old 04-21-2002, 06:23 AM
Petah's Avatar
Default Re: Had a wierd problem tonight....any help?? (samdawgsol)
Are these relays found on the clusters? What do they look like? If they are not on the back of the cluster, where are they???
Old 04-21-2002, 08:10 PM
Petah's Avatar
OK....i am pretty sure it's the cold weather. Did the same thing tonight.....but was working fine the whole day. Any one else has any ideas??
Old 04-23-2002, 03:33 AM
itRgirl's Avatar
https://honda-tech.com/zerothread?id=170016
patrickstar
04-23-2009 10:28 PM
boostincoupe
01-29-2004 08:35 PM
Quick Reply: Had a wierd problem tonight....any help??
