H22A in EK..WHAT AXLES???
Old 09-20-2011, 06:05 PM
spraymaster's Avatar
Default H22A in EK..WHAT AXLES???
WHAT AXLES DO I PUT FOR DRIVER SIDE? PRELUDE OR EK DON'T WORK, HOW DO I LOOK THEM UP??? PLZZZZ HELPPPP
Old 09-20-2011, 06:24 PM
apexi_rsx's Avatar
Default Re: H22A in EK..WHAT AXLES???
http://cgi.ebay.com/ebaymotors/ek-h2...item3cbc29744a your using integra front spindles im assuming as he said integra drive side with 90-93 Honda Accord Ex or Lx model midshaft. Acura Integra passenger side axle that has been cut down 1/2" on the shaft and has an Accord 90+ Inner joint put on it. Raxles.com sells this 1 custom axle. its a hybrid kind of axle with the f22 inner and a integra outter.
DELshaneSOL's Avatar
94 integra on the driver side.
or custom axles from hasport or raxles.
Old 09-20-2011, 07:18 PM
thanks fellas, i gatta try that... so if i get a axle for a 94 integra driver side, it will fit perfect??
Old 09-20-2011, 08:40 PM
Mfoehrkolb's Avatar
I am using AVID mounts, and just normal 32mm spindles... I use DA axles (not gen3)... DA specific axles are about half inch or more longer than the gen 3 and it clears up a lot of axle problems.
I have got reman ones with lifetime warranty... so next time i break or next time they start clicking... just free replacment... eff it..
but yeah... avid mounts and DA axles with the C clip widened a bit into the trans... no problems what so ever... and cheap.
Old 09-20-2011, 08:45 PM
kozanatos's Avatar
I thought you use driveshafts?
Old 09-20-2011, 08:53 PM
Mfoehrkolb's Avatar
--- http://www.traxxas.ru/products/nitro...veshaft_02.jpg
you mean that? lol... i think your right! 8x
Old 09-20-2011, 08:56 PM
kozanatos's Avatar
Yeah that ! I take up two lanes and I had to build my frame out and use lambo doors, kind of a difficult swap for an ek.
Huh? "I like carrots, but carrots can kill me. Im going to go eat some carrots" type of logic here
Old 09-20-2011, 09:11 PM
Mfoehrkolb's Avatar
--- DO NOT use gen 3 axles. They are shorter than the DA axles. You want the extra length to prevent any of the binding issues and pop outs.
Old 09-21-2011, 05:00 AM
So 90 integra axles???
Old 09-21-2011, 05:25 AM
fallrivercolin's Avatar
yes. 90-93 Integra axles with accord inners
Old 09-21-2011, 09:08 AM
Mfoehrkolb's Avatar
--- 90-93 is DA... so yeah. Just use those, and for the transmission side, you want to widen the C clip some so it's a lot more secured inside the trans. People have problems with popping out (i never did)... The combination of longer axles and widen the C clip never gave me an issue.
You do not need to use the accord, or prelude inners. Once you get into that, it becomes a bit more of a task to swap axles etc. Which going by this thread, you are kinda lost as it is with this h swap process. Simplicity is where its at when it comes to mechanical parts... straight up DA axle, widened C clip. Done.
Old 09-21-2011, 01:16 PM
Ur not Lyin bout me being new to the H swap scene lol, but one thing I'm still confused on is I looked up DA axles but the inner part of the axle that goes to the midshaft is male, it needs to b female to go in the midshaft, so I assume I have to Change the end of the axle so it goes in???
Old 09-21-2011, 01:19 PM
easy_vtec's Avatar
Correct. Or go with an aftermarket swap axle. Goodluck!
lowlowloweg6
01-07-2016 04:12 AM
manchildteggy
02-16-2012 06:25 AM
butter99
11-30-2008 12:49 PM
lowtegsr
01-10-2008 03:45 PM
xH22xTEGx
01-12-2006 06:48 AM
Quick Reply: H22A in EK..WHAT AXLES???
