H22 swap??
Old 06-29-2011, 01:36 PM
markass420's Avatar
Icon2 H22 swap??
New to this. Guna do H22 swap into a 99 civic ex. Have the H22 BUt no harness will my civic harness convert? not sure wht year the motor is.Also What all will i need to complet the swap?? any help would be great thanks..
Old 06-29-2011, 05:30 PM
The Grumpiest
grumblemarc's Avatar
Default Re: H22 swap??
You might want to post this in the Hybrid forum.
Old 06-29-2011, 05:55 PM
95EG2's Avatar
yes u can use stock harness but have to wire up some things (vtec, iab, ect.
Old 06-29-2011, 06:29 PM
Ek Forever y0!
Libertariat's Avatar
Indeed, it's easiest to use the stock harness and just wire it for the new engine.
Your question is very vague. You need a lot of things for the swap. H2b kit, mounts, transmission, alternator, header, belts, radiator hoses, etc.
Old 06-29-2011, 07:02 PM
that_boy_sammy's Avatar
Im running a p2t obd2(00 si) ecu with a stock harness. I got my h22(94) complete and bought hasport mounts for it. Im also using the h22 LSD tranny it came with I just had to drill the shift linkage holes a tad bit higher. Also I had to buy 93 DA integra axles and an aftermarket radiator. That pretty much sums up my swap other than fixing about 5 c.e.l's to convert obd1 to obd2. If your H is 97+ the wiring part is cake.
Old 06-30-2011, 01:32 PM
H-T Premium Sponsor
Hasport's Avatar
you will need a mount kit, axles, and wiring conversion
we can do the wiring conversion for you
we would need the h22 engine harness and the civic engine harness
HEIGHTSR
04-15-2010 05:44 PM
teefunk01
Northeast (Sales)
10-21-2008 04:40 PM
slo_hatch
03-31-2008 04:27 PM
-Bionic-
09-08-2003 06:55 PM
Quick Reply: H22 swap??
