h22 ek shaking like crazy?
well i got a h22a1 swaped ek its got hasport mounts. so anyways, its allways shook the car a bit. that should be ecpected with the hasport mounts. but it started shaking hardcore the other day. i look under the hood the drivers side mount bolts were lose im like hey theres my problem. titin the mount bolts on both side mounts. take it up the road and its better but still not drivable. this isnt some small vibration its enuff to shake stuff otta the door pockets.
it doesnt shake unless im accelerating its good in first but from there on it goes nuts. it gets faster with more rpms (starts from around 2500 like a hammer at 4500 its beatin like a jackhammer on steriods.) any body got a clue.
Re: h22 ek shaking like crazy? (rexadict)
Check the axles you are using. Some of them have ABS ring on them. WHich if your car has no ABS you should take it off, because it will most likely make it shake. NOt sure if thats the problem though, but I have a H22 in a civic, and i had to take off the ABS ring to make the shaking stop.
OG Tech
Re: (rexadict)
ya the axles will do that. If you keep it running like that, it will seize up on u and lock. Change ur axles dude. and ur axles might be out of line.
bambbrose
06-13-2007 09:22 PM
