H-T HELP!. battery fuse keeps blowing
Ok hooked up my JRSC. Everything is done time for start up. Try and start nothing happens, nothing in car is coming on. So i check the fuse box under the hood and see the Batter Fuse 80A is blown. SO i buy a new one install it, Negative terminal isnt connected so i connect the Negative terminal to the battery and....spark spark its on check fuse, and its Blown again.
1. Why does it keep blowing after i coonect the negative?
2. should i connect both terminals first then replace the fuse?
3. Please any help would be great blew 3 of them already one more left.
Re: H-T HELP!. battery fuse keeps blowing (95civicSirCoupe)
actually i noticed in my engine bay that one of my hyper ground wires isnt connected to anything i guess i never connected it back when i took them off
1/ Can this cause the problem????
the order has more to do with safety... you likely have a short somewhere in that circuit. when you connect the ground to the battery that makes all of your "grounds" ground. (i swear there is a better way to put that...) there's a hot wire somewhere grounding and when you hook the neg bat cable it shorts the fuse. start lookin'
Re: H-T HELP!. battery fuse keeps blowing (hondamark35)
is the power wire going to the alternator tightly secured. if its loose it will cause a voltage spike and blow the fuse
Re: H-T HELP!. battery fuse keeps blowing (turbociviccoupe)
thanks will try tom.
also some one told me to check if my alt. is touching my charger. can anyone confirm that that can be a cause
found the problem. it was the alt touching the charger via white powerstrip. All i had to do was take off the iwre and turn it around.
HotImportNightHonda
13
05-22-2023 05:10 PM
FastHatch90
04-03-2006 07:47 PM
