gsr front knuckles on an ek- does abs matter??
looking into buying gsr front brakes for my hx coupe. the hx does not have abs. can i get abs gsr brakes/knuckes and have them work fine in a non abs car? or do i need non abs brakes?
Re: (=GAMEOVER=)
ok so then i should be good to go with abs complete knuckles on a non abs car, i can either cut off the wires or just leave them there, but i dont hook them up to anything..
be professional
Re: gsr front knuckles on an ek- does abs matter?? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">looking into buying gsr front brakes for my hx coupe. the hx does not have abs. can i get abs gsr brakes/knuckes and have them work fine in a non abs car? or do i need non abs brakes? </TD></TR></TABLE>
As they said, ABS doesn't matter.
You also don't need to get brakes specifically from a GSR. All '94-01 Integras (RS/LS/SE/GS/GSR) used the same front brakes, with exception of the Type-R. '92-00 Civic EX and '99-00 Civic Si also had the 10.3" front brakes, albeit with a slightly smaller piston in the caliper.
