grinding noise when im gonna idle?
Old 10-08-2003, 04:49 PM
All_JDM_Si's Avatar
Default grinding noise when im gonna idle?
Hey, I have a 99 Si. And just yesterday my car started making a funny noise. When im drifting down the road in gear it makes this grinding noise from under the car. but if i hit either the gas or the brake it goes away while my foots on one of the pedals. the moment i take my foot off the noise is back. sometimes its make a quick noise when i hit the lutch too. but only sometimes.
any idea what this could be?
thanks
Old 10-08-2003, 05:32 PM
All_JDM_Si's Avatar
Default Re: grinding noise when im gonna idle? (All_JDM_Si)
any help here????
Old 10-08-2003, 05:34 PM
TrickHonda98's Avatar
when you're drifting down the road?
Old 10-08-2003, 05:49 PM
All_JDM_Si's Avatar
Default Re: grinding noise when im gonna idle? (TrickHonda77)
drifting as in , not accelerating. trying to get the point across that im not pushing the gas
Old 10-08-2003, 06:00 PM
civickidd99's Avatar
pretty sure that might be the throw out bearing....may be wrong, but
Old 10-08-2003, 06:09 PM
TSPeed Factory
AzntaggeR's Avatar
Default Re: grinding noise when im gonna idle? (mox99)
yea, throwout bearing or input shaft bearing. my car has the same problem.
Old 10-08-2003, 06:42 PM
LowTEC SaiMike's Avatar
Default Re: grinding noise when im gonna idle? (AzntaggeR)
my friend has been driving with a messed up bearing for a while , but he hasn't done anything to it yet
Old 10-08-2003, 06:59 PM
Jmunk's Avatar
Maybe a lose heat shield ??
Old 10-08-2003, 07:31 PM
globlctzn's Avatar
if its a reasonably loud grinding when you're off the gas, most likely its your input shaft bearings in your tranny.
Old 10-08-2003, 08:07 PM
solo2slocivic's Avatar
if it is a bearing you should fix it now while it is only one or two bad ones let it go and you might as well junk the tranny
Old 10-09-2003, 03:30 AM
93CivicSI's Avatar
Input shaft bearing or Throwout bearing -
Check this Write up from Bauley Civic https://honda-tech.com/zerothread?id=596873
Might not be excatly what you need, but will point you in the right direction no matter.
b20beast83
Transmission & Drivetrain
01-12-2009 01:39 PM
JokerX-1.6T
14
04-05-2007 11:33 AM
IGotVTECyo
11-15-2006 06:05 AM
FK00GSR
07-19-2005 05:23 PM
boostinb20vtec
04-22-2004 04:32 PM
Quick Reply: grinding noise when im gonna idle?
