grinding noise when i turn left - Honda-Tech
Old 03-28-2010, 12:19 PM   #1
Default grinding noise when i turn left
it doesnt do it when i turn right. i replaced the axle and all brake parts up front so it isnt them. its not a clicking noise its more of a grinding. anyone have any ideas?
724chris is offline   Reply With Quote
Old 03-28-2010, 01:02 PM   #2
mikeycivic's Avatar
Default Re: grinding noise when i turn left
um need more info
mikeycivic is offline   Reply With Quote
Old 03-28-2010, 02:08 PM   #3
like what?
Old 03-28-2010, 02:09 PM   #4
mikeycivic's Avatar
like when did it start?
Old 03-28-2010, 02:38 PM   #5
I had my driverside balljoint lower break on me while driving.since then
Old 03-28-2010, 02:53 PM   #6
mikeycivic's Avatar
well did you fix the balljoint?
Old 03-28-2010, 03:12 PM   #7
ya or it wouldnt be drivable
Old 03-28-2010, 03:14 PM   #8
Linked's Avatar
how many miles does the tranny have on it? what the condition of the tranny fluid,
may be your differential
Linked is offline   Reply With Quote
Old 03-28-2010, 04:37 PM   #9
would that happen from turning one way? i have a leaky axle and have to add fluid often. could that be a reason?
Old 03-28-2010, 05:04 PM   #10
Ludeon19slol's Avatar
Low fluid level mite be the problem. See if it still grinds rite after u add fluid.
Ludeon19slol is offline   Reply With Quote
Old 03-28-2010, 05:21 PM   #11
Ill try that out and get back to you
Old 03-28-2010, 07:03 PM   #12
fasterthanueg's Avatar
ive had this problem before and it turned out to be a bad wheel bearing
fasterthanueg is offline   Reply With Quote
Old 03-28-2010, 07:09 PM   #13
I had this issue before when turning right after replacing the cv boots, axles etc etc. Check your brake guard. That was the case for me. I just bent it out with a screw driver and the noise went away. Might be the same issue for you probably
MrExclusive is offline   Reply With Quote
97 Accord EX makes a grinding noise when turning... HacksawMark Honda Accord (1990 - 2002) 0 07-23-2015 08:35 PM
92 Civic DX Grinding noise coming from driver side wheel well. aystupet Honda Civic / Del Sol (1992 - 2000) 9 03-22-2011 09:46 PM
weird noise????? 92tegzz Honda Civic / Del Sol (1992 - 2000) 5 01-26-2007 08:10 PM
grinding noise latinracerct Honda CRX / EF Civic (1988 - 1991) 6 07-15-2006 11:14 PM
grinding noise when car is moving........bearings? dabomb Tech / Misc 1 01-08-2006 07:35 PM
Tags
2000, 2006, accord, brake, civic, crv, grinding, honda, left, make, noise, pilot, sound, turn, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
