greddy turbo owners, I need any help available
New User
I am going to order the turbo, BOV type S, and Type 26R intercooler. I need to know if you've installed one yourself, or know about little irritations about the install, to post them and let me know. I'm most likely going to use the black box with the turbo, along with the supplied fpr.....I'm only going to run the stock boost pressure.
Can the piece that goes into the back of the block (oil supply fitting) be connected with oil lines? Because I've heard bad things about putting the T directly on the block. What is the thread size of the oil ?banjo? The intercooler should bolt into the mouth opening on a 94 civic correct? Is there any fitting issues with any of this? Vacuum (sp?) lines.....is there a best place to catch it? (fpr line?...one of the other bigger lines?)
Yes I've searched and come up with a lot of answers to my questions. However, many of the turbo questions and what not are not directed toward SOHC motors, so your reply is greatly appreciated.
Thanks,
Rick
Thanks,
Rick
