Ghetto rig vtec wiring
Old 12-18-2006, 08:11 PM
blue_hatch's Avatar
Default Ghetto rig vtec wiring
i just swaped to a z6 motor. im using the dx harness and want to wire up for vtec. on the vtec oil pressure switch which one is the ground(black) and the hot wire(? color).
i guess im trying to say is the wire closest to the distributor is it the ground or positive? so i can run it to the ecu harness and ground the other wire. the solenoid is only one wire so im good on that. thanks
Old 12-18-2006, 08:16 PM
schardbody's Avatar
run the blue wire to pin D6, and then run the black ground wire from the plug to a good ground. then run the green wire from the VTEC solenoid to A4.
Old 12-18-2006, 08:32 PM
blue_hatch's Avatar
Default Re: (schardbody)
thing is i dont have the plugs that hook up to the oil pressure. so im going to custom make a plug, but i need is some one with a z6 head to tell me if the wire on that plug that is closest to to dizzy is the ground or the hot wire.
CrooksEK
07-23-2014 11:45 AM
ahkbird
08-25-2012 07:59 AM
Straits514
02-15-2011 08:07 PM
mr. carpenter
05-05-2004 09:47 PM
Quick Reply: Ghetto rig vtec wiring
