gas smell, when cornering??
Old 09-13-2004, 12:27 PM
GUNNER666's Avatar
Default gas smell, when cornering??
in my buddies car, if you take a corner somewhat but not really hard (30 kmph), it smells like gas really bad, and it coming from just above his tank, could it be a hole, or his fuel pump? what could be causing this???
Old 09-13-2004, 12:41 PM
b18bme's Avatar
Default Re: gas smell, when cornering?? (GUNNER666)
Mines did the same thing but it was because my dumbass left the gas cap at the gas statibn.
Old 09-13-2004, 04:53 PM
GUNNER666's Avatar
Default Re: gas smell, when cornering?? (b18bme)
well its definetly not the gas cap, although one time he did forget it on his roof
Old 09-16-2004, 09:18 AM
GUNNER666's Avatar
anyone???
Old 09-16-2004, 09:22 AM
countysupercop's Avatar
This may not help at all but, my (don't laugh) Ford Tempo does the same thing. I can't figure it out at all.
Old 09-16-2004, 09:32 AM
Apocolipse269's Avatar
Default Re: gas smell, when cornering?? (countysupercop)
*sarcasm ahead*
you should re-grease your Axle joints and take ur transmission in for maintainence. then you should check ur winshield wiper fluid.
take the car apart and check for leaks u dumbass. If you smell it, its oviously coming out so check where its comin from and then fix it
Old 09-16-2004, 09:59 AM
b18bme's Avatar
Default Re: gas smell, when cornering?? (Apocolipse269)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apocolipse269 &raquo;</TD></TR><TR><TD CLASS="quote">*sarcasm ahead*
take the car apart and check for leaks u dumbass. If you smell it, its oviously coming out so check where its comin from and then fix it</TD></TR></TABLE>
Nicely put
Old 09-16-2004, 10:41 AM
dropgear's Avatar
What smells like gas is often exhaust fumes before they hit the catalytic converter. Check those gaskets there are as well.
Old 09-16-2004, 10:58 AM
TheIntegraGuy's Avatar
Check your Fueltank seal... It may be warped..
quirarte626
02-09-2010 12:28 PM
higgunscrx
02-25-2007 06:31 PM
TealCivic93
04-08-2006 09:31 AM
beakert216
08-08-2002 08:08 AM
SpoonPL
07-11-2002 06:52 PM
Quick Reply: gas smell, when cornering??
