Gas smell and gas leaking from tank (92 civic DX)
Got another issue...this time with my 92. I started noticing a really strong gas smell near the rear drivers side of my car, it would get worse and worse the more I drove and the fuel tank seemed to be building up a lot of pressure. I got under the car and could see that gas was running down the bottom half of the gas tank, and I traced the leak to a rusty spot where the tank halves were welded together.
It got so bad that there was a small amount of gas pooling under the car so I replaced the fuel tank with another used one and swapped over the fuel pump and sending unit. It seemed like it fixed it, but then a week or so later I started to notice the same smell. I checked underneath and I see gas running down the bottom half of the tank again and the tank is still building up pressure. I thought it was a clogged vent line so I checked with a mity-vac and the line from the charcoal canister wasn't clogged, nor was the 2 way valve. I put vacuum to the fume vent outlet on the tank, with the gas cap off, and the vacuum will build as I pump it up and slowly bleed off. It seems like there is some restriction in the outlet but I doubt that I got two bad tanks in a row to cause this. There are no CEL codes.
Has anyone ever cut open a tank? Is there anything in the fume vent on the tank to restrict the outflow? Anyone ever had this issue?
Another idea, I think my fuel pump might be overheating causing the fuel to heat up too much and causing the pressure buildup. Has anyone heard of this happening?
The Grumpiest
Re: Gas smell and gas leaking from tank (92 civic DX)
It wasn't related to my fuel pump.
During one summer, if I would refuel and try to top it off as much as possible, I would find that the fuel would be running out of the tank via the filler neck and down the side of the car. Needless to say I don't do that anymore so I don't have that issue.
I replaced the pump/sending unit asm with another that I had laying around, and I think it fixed it. I noticed the rubber pressure hose was a bit kinked from when I had replaced the tank so I'm not sure if it was that or the pump but it doesn't seem to be building pressure now.
