fuse box under dash and alarm problem
Old 10-29-2006, 01:05 AM
john666's Avatar
Default Re: fuse box under dash and alarm problem (jdmjunkieXL)
each of those slots are different. one has power always. one has power when the lights are on.. and etc.... you should use a test light to see which is which you could tap the wires together if thats what you need.. i remember i had to when i had afew different things
Old 10-29-2006, 01:36 AM
jdmjunkieXL's Avatar
Default fuse box under dash and alarm problem
are the 5 one-pin plugs on the fuse box all the same because i just recently installed the pwjdm 96-98 foglights and i had to plug in the the 2 one-pin connector to the fuse box i had to use the 2 connectors on the left but there was a wire that was in the 2nd connector from the left that i unplugged and it was for my alarm..just wondering if i could put that wire in a different connector or should i tap it in to the same wire?..that wire i took off makes my exterior and interior lights flah when the alarm is engaged/disengaged thanks in advance
Modified by jdmjunkieXL at 1:49 AM 10/29/2006
Old 10-29-2006, 10:03 AM
Default Re: fuse box under dash and alarm problem (john666)
bump!
Old 10-29-2006, 10:22 AM
BogusMalone's Avatar
The answer to your question is in the diagram you included. It says option connector index and says when each one is hot.
SiRCiviC94
09-15-2012 04:56 PM
c4ptiv3
01-27-2011 11:07 AM
zXeX
09-02-2009 07:34 PM
Homotor
02-09-2007 09:56 AM
nerdish
08-09-2001 03:13 PM
Quick Reply: fuse box under dash and alarm problem
