fuse #19
fuse #19
okay this fuse keeps popping. it sarted about 2 weeks ago. i got off of wrk went to turn my headlights on and my guage cluster didnt turn on. i didnt think anything of it (not knowin my tail lights werent on)i thouhght i jus that a fuse popped. so got home replaced the fuse and it popped again. i then started makin sure my connections to my fuse box were tight. when i did this i put a new fuse in turned the lights on it they worked. so jus yesterday night it happened agian. no dash lights, tail lights, or parking lights. i replaced the bulbs, checked for shorts, and replaced brake light switch. theres no signs of corrosion or any open wires grounding out. so now i turn to u guys. thanks in advance
Re: fuse #19
Re: fuse #19
Read the diagram. Should be similar for your Del Sol. Just carefully pry the switch out of the dash and unplug it. Then take a drive in the car with the lights on to see if fuse 19 no longer blows.
Re: fuse #19
tried this and it still pops. i replaced all my bulbs again and it worked for about 5 minutes down the road. then POP! is there a way to bypass that fuse, maybe put a jumper for the time being so that i can drive at night??
Re: fuse #19
sounds to me like your grounding out some where on your headlight harness... i had the same thing ... i had wire pinched for my city lights that kept making my fuse pop every time
Re: fuse #19
yea im pretty sure im grounding out somewhere but where? i took almost me whole headlight harness off to make sure my wires are good and the same with the taillights. i hadnt tried my liscence plate though? ill do that next
Re: fuse #19
ok found the problemo. ok it seems that the dim light wire from behind the radio harness gets power from the fuse #19 wire. well somehow my dim light wire grounded out against my radio therefore grounded out the whole wire, frying it to pieces. so i the pulled the dash harness and followed the wire. then depinned the connectors ran new wire,m checked other wires for and splittage. and when i was done connected everything. and now it works perfecto. thanks to everyone for rthryre help
[Ennis_D]
02-08-2013 06:40 PM
JDM H22
12-13-2007 01:59 PM
