99 Civic EX - CEL code 20
Old 05-15-2012, 02:10 PM
DZO
DZO's Avatar
Default 99 Civic EX - CEL code 20
Sorry if i posted this thread on the wrong place. I have a 99 civic ex 5spd and all of sudden it wouldnt start after 2-3 cranks. the battery died. Got a new battery and now cel pops up. I checked the cel and got codes 20(electrical load detecter) 41(primary oxygen sensor heater), and 65(Secondary oxygen sensor heater wires). Im new at this and have no idea how to take care of this. Please help me. Thanks
Old 05-15-2012, 02:42 PM
The Grumpiest
grumblemarc's Avatar
Default Re: CEL popping up?
If you reset the ECU what codes return?
Old 05-15-2012, 02:47 PM
DZO
DZO's Avatar
Havent reset ecu yet. How u do that?
Old 05-15-2012, 04:22 PM
jbpnoman's Avatar
Detach the positive battery terminal, try to crank the car, reattach the battery terminal.
Old 05-15-2012, 05:46 PM
DZO
DZO's Avatar
Ok i reset the ecu and now all i get is code 20(electrical load detector). How do i fix that?
Old 05-15-2012, 09:41 PM
93HondaDelSolSi's Avatar
See attached images for help. :D
Old 05-15-2012, 09:48 PM
forgot to add connector view for the ECU
Old 05-16-2012, 05:55 AM
DZO
DZO's Avatar
Where is ELD located? And its just 3pin connecter?
Old 05-16-2012, 04:10 PM
ELD is located in the underhood fuse/relay box as stated in the pics.
Old 05-16-2012, 04:13 PM
This is an automatic, but the ELD is in the same location.
Old 05-16-2012, 04:58 PM
Former User's Avatar
Check whether 7.5A dash fuse 15 is blown.
Old 05-16-2012, 10:49 PM
DZO
DZO's Avatar
Default Re: 99 Civic EX - CEL code 20
No, 7.5a fuse is not blown. I even put in a new 1. Ive been having problems with no brake lights ever since i got this car. Tail lights work. Just no lights when step on brakes. Put in new brake switch and still nothing. I dont know if this cause my cel to come up. Anyways, i left the battery unhooked for 2 days now while i research and today when i went to start it, no more cel. Dont kno if its fix or will the cel pop up again.
Weeman_JDM
08-20-2012 04:57 PM
teamvirus
Honda Civic (2001 - 2005)
05-28-2009 11:32 PM
checkenginelight2
05-31-2008 05:15 AM
tx95excoupe
04-27-2007 04:07 PM
GeorgeY
06-29-2003 08:59 AM
Quick Reply: 99 Civic EX - CEL code 20
