Fuel pump relay removal - Honda-Tech
Old 06-04-2010, 01:28 PM   #1
drhoward07's Avatar
Default Fuel pump relay removal
1993 honda del sol S.
my car would crank and i couldnt hear my fuel pump cut on. i disconnected the relay and ran a jumper, fuel pump then cut on. so ive determined that its the relay. my question is how do u remove this relay. i ve been working at it for the past hour with now luck. anyone have a suggestion?
drhoward07 is offline   Reply With Quote
Old 06-04-2010, 01:54 PM   #2
Technical Hero
HondaPartsHero's Avatar
Default Re: Fuel pump relay removal
HondaPartsHero is offline   Reply With Quote
Old 06-04-2010, 02:00 PM   #3
Gunmetal_B20_Hatch's Avatar
it should be held on with 1x 6mm bolt, IIRC.
Gunmetal_B20_Hatch is offline   Reply With Quote
1993 Honda civic DX sgtyates Introduce Yourself 1 05-27-2016 05:42 PM
Fuel pump girlcrx Honda CRX / EF Civic (1988 - 1991) 2 03-09-2014 07:04 PM
81 Prelude Fuel Relay Issue djkube Honda Prelude 2 06-02-2013 06:23 AM
which wire is my fuel pump power line? Clash0901 Honda Civic / Del Sol (1992 - 2000) 3 07-04-2009 02:15 PM
Fuel Pump Relay Location??? TurboKneeGrow Honda Civic / Del Sol (1992 - 2000) 9 04-30-2008 06:04 PM
Tags
1993, del, diagram, dol, dx, fuel, fuse, hatch, hatchback, honda, location, pump, relay, removal, remove, sol, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
