FUEL PRESSURE PROBLEM???
Old 08-26-2003, 04:36 AM
SLOAZZ95's Avatar
Default FUEL PRESSURE PROBLEM??? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i have a 94 ex civic w/z6 motor. yesterday i put a b&m fuel pressure guage on it. when i would shut it off it would hold pressure at 35-40 psi. and keep that pressure until the next time i started it. last night i put on a 99 gsr fuel pump(for the higher lph and my was still original) and now if i shut it off it dosnt hold any pressure at all. if i let it sit it takes alot of cranking to start< i assume its because it has to build pressure. any ideas y its not holding pressure. Could it be because my car is mpi and the pump is efi. or do u think i have a leak in the pressure line somewhere. any suggestions or has anyone else done this and ran into this problem. will this problem cause the pump to wear out faster?? any help would be great.
Modified by SLOAZZ94 at 2:05 PM 8/26/2003
Old 08-26-2003, 07:05 AM
SLOAZZ95's Avatar
Default Re: FUEL PRESSURE PROBLEM??? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (SLOAZZ94)
BUMP, Come on people i can't belive that noone here has any ideas on this. all u guys with 1800 post and u havent heard or know about fuel pressure. come on people, help me!!!!!!
Old 08-26-2003, 08:08 AM
aw1234dude's Avatar
I just put a GSR fuel pump in my cx yesterday too. When I tried to crank it over it took a while and thats when i realized i left the gas cap off. Once i screwed it back on tight it cranked right over. So i'm guessing that if there is a leak anywhere in the tank area it will be sluggish to start. Maybe you should recheck the bolts around the pump, make sure all your hoses are tight, and double check the gas cap.
aemlet
Honda Civic (2001 - 2005)
10-14-2013 08:12 PM
SPOOLINmatt
06-02-2009 06:49 PM
b20beast83
01-11-2009 02:52 PM
Familycarfromhell
01-27-2003 07:54 PM
Quick Reply: FUEL PRESSURE PROBLEM???
