Fuel line Nut
Old 04-13-2015, 05:32 AM
reww's Avatar
Default Fuel line Nut
I am missing my fuel line nut to hold the line onto the fuel rail. Picture included, could someone please tell me what size, or where to get it? Motor is a D15b Vtec/D16z6
Old 04-13-2015, 08:55 PM
Former User's Avatar
Default Re: Fuel line Nut
It's not a regular nut. It's a damper.
Honda Automotive Parts
Old 04-16-2015, 07:09 PM
Needs to be About 20% Cooler
DieMaster's Avatar
i have a standard nut on mine. it dosent have the top hat shape. just a capped nut. always assumed it was stock that way.
Old 04-16-2015, 07:28 PM
What car/engine do you have?
Old 04-17-2015, 03:48 AM
Resident Gearhead
BryanM.'s Avatar
I always wondered about those dampers. None of my 92-00 Civics had them, DOHC or SOHC.
Old 04-17-2015, 05:25 AM
Majestic Honda shows that the 95 but not the 92 Civic D16Z6 and D15B7 have the damper.
Majestic shows that neither the 97 Civic D16Y7 nor the 00 Civic D16Y8 have the damper.
Old 04-17-2015, 12:35 PM
I never narc'd on nobody!
NotARaCist's Avatar
And yet, my 98 Y7 had it, and my 98 B1 has it.
Old 04-17-2015, 02:16 PM
DieMaster's Avatar
95 DX hatch with D15B7 all stock. (that i know of)
Old 04-17-2015, 02:35 PM
PHANTOM MENACE
24TEN's Avatar
I recall speaking with a person at my local dealership parts section and he said that the damper was eventually superseded by the plane nut. He was still able to get the one with the damper though because I wanted it but I never used it (I went to the junkyard and just grabbed the simple nut version as a temporary fix which never gave me any problems).
EDIT: Disregard, I didn't use a regular nut. I had a chance to look and it was a pulsation damper from the junkyard. See post below for clarification.
Old 04-19-2015, 01:16 PM
Seagull Management
94EG8's Avatar
Some use the regular nut, some use the damper pulsation nut, they're not interchangeable. If the big hole in the banjo fitting where it goes over the stud is the same on both sides it uses the regular nut, if one side is larger than the other it uses the damper pulsation nut. Also the damper pulsation nut uses a weird crush washer on the nut side.
EK9r!der
18
08-23-2012 09:57 PM
dodger
12-08-2011 03:10 AM
Type-Spaz
03-30-2011 02:12 PM
civickiller
03-27-2004 06:43 PM
Quick Reply: Fuel line Nut
