fuel gauge doesn't work - Honda-Tech
Old 05-26-2009, 09:10 PM   #1
changknows's Avatar
Default fuel gauge doesn't work
I checked the fuses and tried hooking up a different cluster and the fuel gauge doesn't work. Is there a sensor or something I should check? and where would i find it? How do I figure out if the wires are bad?
changknows is offline   Reply With Quote
Old 05-26-2009, 09:15 PM   #2
Murk 'EM's Avatar
Default Re: fuel gauge doesn't work
do you have a repair manual? if not get one it is going to be to your advantage.. yes their is a sensor how ever their is no way we can help you with out info.. year.. model.. anything will help
iv never had a problem with my sensor but i do believe it is in the fule sending unit itself in the tank
Murk 'EM is offline   Reply With Quote
Old 05-26-2009, 09:29 PM   #3
changknows's Avatar
My bad, I have a 93 civic hatch dx. I have a haynes manual which is useless for the most part. Is there a way I can check the wires without having to rip my car apart?
Old 05-26-2009, 09:33 PM   #4
Murk 'EM's Avatar
yea if you can wait till tomorrow i can try to get the pin outs for what the fuel level sensor is
the haynes should have wiring diagrams that show you everything you need to know to check it
Old 05-26-2009, 09:41 PM   #5
buckner2009's Avatar
hey bud i had the same problem on mine' all u got to do is if u check fuse and its good
and gauge isnt messed up its called your sending unit its write next to your fuel pump assembly under neath the back seat it go tto unscrew it and replace it that fixed my problem gauge mint now i hope that helps u; u can also jump the wire that clips into it to check if the gauge works or not' just dont let it get to fuel or it will stay there and break' =]
buckner2009 is offline   Reply With Quote
Old 05-26-2009, 10:02 PM   #6
Icon_Ed6's Avatar
^^^Do this before you just start replacing things. 2 identical problems aren't always due to the same cause.
Icon_Ed6 is offline   Reply With Quote
Old 05-27-2009, 01:23 AM   #7
MilanoCpe's Avatar
u could always take ur cluster off and check the wires behind it. It's not gonna hurt to try.
MilanoCpe is offline   Reply With Quote
Old 06-01-2009, 08:39 PM   #8
Icon_Ed6's Avatar
so what happened wit this???
Old 07-29-2009, 04:13 AM   #9
Hi,
please i need assistance from u guys. the "check engine" light came up on my dash. within 10 mins of driving, my fuel gauge went from almost full to empty. Now, d check engine light has gone off, but d gauge remains at empty. I still have an almost full tank. I removed the battery head overnight hoping that it will somehow reset itself. This did not work.
how do i tell what the problem is? Is it from the ecm, sending unit or the gauge? how can i test for these? the car is a 2006 Honda Accord EX. Thank you
gondwana1 is offline   Reply With Quote
Old 07-30-2009, 01:52 AM   #10
The check engine light is back on and the fuel gauge remains at empty. Pls any ideas?
Old 07-30-2009, 12:48 PM   #11
Pull the CEL codes and check the fuel gauge sending unit near the fuel pump.
Former User is offline   Reply With Quote
Old 09-07-2009, 03:29 AM   #12
Thanks RonJ@HT; I have replaced the sending unit and it works perfectly now.
I have another problem now.
The transmitter on the key unlocks the driver door but when you press a 2nd time, it does not unlock the passenger and rear doors - instead i hear a clicking sound as if they are trying to unlock.
Using the key in the key cylinder produces same results (1st turn unlocks driver door but 2nd turn does not unlock the remaining doors). I cannot use the key to wind down the windows as a result.
However, the door panel master switch inside the car, locks and unlocks all the doors.
Also, the four doors lock on their own when i open and close the driver door with the engine running.
I think this problem may have to do with the MICU or the door multiplexer unit. I have not done a diagnostic on the car since the MIL is not on.
can anyone help me with ideas/explanations so i can fix the problem? Thanks in advance
Integra Type R fuel gauge problem Alex793 Tech / Misc 1 10-14-2012 10:48 PM
fuel gauge on my si cluster doesn't work OneSloEk9 Honda Civic / Del Sol (1992 - 2000) 1 12-19-2010 01:22 PM
Fuel gauge and fuel light... ultima.maniac Honda Civic / Del Sol (1992 - 2000) 3 06-10-2008 03:24 PM
fuel pressure gauge bondo Forced Induction 6 10-09-2006 07:45 PM
Speedo/Tach/Temp/Dash Clock Not Working NickGSR95 Acura Integra 11 08-14-2004 09:34 AM
Tags
90, accord, civic, fuel, gage, gas, gauge, honda, level, oddessy, problems, replace, replaceing, sensor, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
