thermostat question ?
Old 09-02-2009, 12:59 PM
shoklid's Avatar
Default thermostat question ?
im being a retard and cant remember. haha ok i am using a 180 and my temp never is normal. its always to cold. do i go with a 195 or a 170 to make the necessary change? im thinking the 195 right?
Old 09-02-2009, 01:06 PM
forcefedferio's Avatar
Default Re: thermostat question ?
195 i believe, just get a stock one from advance it should be like $13 or so.
Old 09-02-2009, 01:08 PM
shoklid's Avatar
well stock is 180 i currently have and my temp is no where close to halfway mark. i also do believe it should b a 195. cause then it would hold the coolant longer and release hotter fluid creating hotter temp for whole system correct?
Old 09-02-2009, 01:13 PM
ah ok, i thought the stock was 195 my fault.
are you sure your thermostat isn't stuck open?
also from my personal experience, none of my civics or my R make it to halfway in the temp gauge, i'm pretty sure that's just normal. They aren't buried on cold like it sounds you are describing, but usually just under half by about a needle and a half width.
Old 09-02-2009, 01:16 PM
shoklid's Avatar
nah it was stuck open replaced it and now it runs so cool i still have no vtec. so therefore it is still to cold. the new thermo is reading on cluster like 1/4
shoklid's Avatar
i wonder if i got a bad thermo even tho its new
Old 09-02-2009, 03:21 PM
shoklid's Avatar
Old 09-02-2009, 03:30 PM
EK ƒox's Avatar
I have had 4 civics so far (2 EGs and 2 Eks) neither of them would get to halfway mark on the temp gauge ever unless something was wrong. The 1/3 mark is a healthy place for the temp gauge to stick at.
Also, i believe your thermostat is fine if it is moving at all, especially if it is brand new!
Old 09-02-2009, 05:02 PM
shoklid's Avatar
well i took it out and put it in diff water temps and its open all the time in the metal kitchen bowl i even used 200 degree water
Old 09-02-2009, 05:19 PM
EK ƒox's Avatar
Return it, and test the new one!
Old 09-06-2009, 10:39 AM
shoklid's Avatar
just got another one installed it and now vtec works like normal but now got a cel code #23 knock sensor f#ck
Old 09-07-2009, 12:31 AM
New User
johnhumid's Avatar
i guess your thermostat is okay if it is moving still and if it is a brand new so just check it out..
_________________
Humidifier filters
ALDJ253
03-04-2014 03:42 AM
gonein60seconds
04-08-2011 12:41 PM
dc4b20
11-24-2007 11:26 AM
ITR632
27
12-26-2005 08:26 PM
superstud
03-14-2004 08:54 PM
Quick Reply: thermostat question ?
