Fuel Filter - bottom bolt won't unthread all the way..
Old 12-29-2011, 03:15 PM
Nihsnek's Avatar
Default Fuel Filter - bottom bolt won't unthread all the way..
So,
I'm trying to change my fuel filter on my 1997 Civic and I've come across a weird problem.
I got the top bolt off fine. I got the bottom bolt loosened (finally)...but it won't unthread completely from the filter. It looks like it's hanging on by 2-3 threads. I try to loosen the bolt, it gets real hard to move, then it gets easy and doesn't move any threads. I can tighten it fine (but not all the way).
I'm assuming the fuel line is crossthreaded into the filter. I'm thinking about taking a dremel to the filter and trying to break the bottom piece off.
Advice? Suggestions?
Old 12-29-2011, 03:36 PM
motegicivic's Avatar
Default Re: Fuel Filter - bottom bolt won't unthread all the way..
Be careful since the dremel could cause sparks. Can you grab the head of the screw with pliers hold the filter and pull and turn the screw to get it off?
Old 12-29-2011, 03:58 PM
Nihsnek's Avatar
Good point, I def. do not want a fire. I think I will not dremel anything since the filters are metal.
I've tried holding the bolt with a wrench while unscrewing and pulling the filter, but it just keeps spinning and doesn't actually unthread completely. Either a thread is crossed/broken on the bolt or inside the filter.
Old 12-29-2011, 04:08 PM
The Grumpiest
grumblemarc's Avatar
Like the top of the filter there is a part on the bottom that you can get a wrench onto for leverage while removing the line. Look at the new filter if you don't know what I'm talking about. I doubt it's crossed threaded.
Old 12-29-2011, 04:22 PM
Nobody123's Avatar
Bolt the bracket back on the firewall if you took it off. Helps to hold the filter in place.
Old 12-29-2011, 08:43 PM
Master Detailer
98civdx's Avatar
Have you tried giving it a good yank?
Mine didn't just pop right off.
Old 12-29-2011, 09:36 PM
Nihsnek's Avatar
Yes, I've tried yanking it and using multiple wrenches for leverage. I even took the filter off the bracket, put wrench on bottom fuel line to keep it from turning, and tried to manually loosen the filter by turning it. It won't go past 5-6 threads.
Old 12-29-2011, 10:48 PM
Master Detailer
98civdx's Avatar
Will it tighten?
Old 12-29-2011, 11:07 PM
Texas4door's Avatar
Originally Posted by 98civdx
Will it tighten?
Yeah, he said he can tighten it back on, but that's not the issue.
IDK how the hell someone could cross thread something like that
Those dern kids XP
Well, if worse comes to worse, you may have to run some new fuel lines, but idk how tough that is ^^;
Old 12-29-2011, 11:39 PM
Master Detailer
98civdx's Avatar
Those dern kids XP
Missed that.
Honestly, if this were me, I would more likely just get mad enough to chop the ****ing line off and run a new one.
Old 12-30-2011, 06:40 AM
If you trace the fuel line I do not think it runs far, you might be able just to replace the bottom fuel line.
Old 12-30-2011, 06:48 AM
kyden's Avatar
that line runs all the way to the back of the car, it is 1 piece.
Old 12-30-2011, 07:22 AM
Maybe I was thinking of the top line, been long time since I looked at the fuel diagram.
You can try a little Teflon tape on the threads screw back up into the filter and then screw down, the tape might thicken the threads a bit and give you leverage to get the screw out.
Old 12-30-2011, 07:30 AM
delsolo95's Avatar
forget about replacing the line, and dont ever use a dremel to cut the fuel line.
first you need one of these
pipe cutter..can be found at auto store
go to junkyard and find same nut slide it on the tube then flare it with this tool
Old 12-30-2011, 07:39 AM
Master Detailer
98civdx's Avatar
You don't need to replace the line. Hell, you could chop it off at the firewall, and run braided lines, with AN fittings if you please.
Old 12-30-2011, 07:42 AM
kaiba's Avatar
You may want to free the filter from the bracket and/or remove the bracket too.
Old 12-30-2011, 09:25 AM
Nihsnek's Avatar
Guess I'll chop the line if I can't get it today. Such a pain for a simple cheap filter.
Old 12-30-2011, 02:40 PM
Try what I said, get some Teflon tape wrap the threads, screw it up into the filter and back down again.
95lscivic
04-18-2007 10:21 PM
Archxor
11-07-2006 04:36 PM
butand50
12-09-2005 05:44 AM
SexyAzNMami
11-19-2004 12:00 PM
michaelpr
03-16-2002 12:18 PM
Quick Reply: Fuel Filter - bottom bolt won't unthread all the way..
