HELP!! RC 550CC INJECTORS RESISTOR BOX?
OK h/t
i just picked up some rc 550cc injectors
i havent yet but i am going to throw them on a b20v with a b16 head...
i been trying to do some research now that i found out they are low impedance injectors....but i get lost with the info....
will i need a resistor box??
i have an obd1 p28 s100 hondata ecu with and obd2 converdion to obd1 ecu harness
going in a 99 civic si
need some help
need some help
Re: HELP!! RC 550CC INJECTORS RESISTOR BOX?
no they dnt require a resistor box
all these years models running 550cc do not require resistor box
1992-2001 Acura Integra (1996+ REQUIRED )
1996-2001 Honda Accord 4 Cylinder Engines (REQUIRED Clips 1992-2000 Honda Civic (1996+ REQUIRED Clips
1996-2001 Honda Prelude (REQUIRED Clips)
1988-1991 Honda/Acura - Must remove OEM resistor box and use OBD1 style injector connecting plugs
so mine is a 99 civic si that means i would need the clips??
do you have a pic of what they look like...
are these injectors high impeadiance injectors or saturated? if high impeadiance then you will need a resistor box. you will need to splice in OBD1 injector clips or RC injector clips to swap these injectors.
you need a resistor box.
http://www.hondata.com/techlowohminjectors.html
You can get one from older Accords, 92 and older Integras, 91 and older Civics I believe. I think there's some "Twinkie" style resistor boxes also. Or I got one that's extra from an Accord. PM me and I could figure out shipping.
ya got the same ones there low need a risistor box; and the clip located under intake many on 96-00 ' eg on driver side firewall' black and yellow' they will run the car if its tuned but wont start good and wont idle good till ur inm boost then run rich' wrong omhs
immorality
05-24-2008 03:46 PM
