torque_spec_question
Old 08-07-2011, 07:15 PM
mengo911's Avatar
Default torque_spec_question
I would like to know The torque spec for THE rod bolt and THE main bolt for THE crank? For d16.... Also would like to know THE torque scqunce for THE main crank bolt?
Old 08-07-2011, 07:18 PM
Former User's Avatar
Default Re: torque_spec_question
D16Z6?
Old 08-08-2011, 08:02 AM
mengo911's Avatar
It a d16a6 but should it be the same torque spec
Old 08-08-2011, 12:01 PM
I'd recommend that you post your question in the EF forum.
Old 08-09-2011, 06:50 AM
turbodcxbro's Avatar
Whats up with all caps on THE???
Go to Amazon or your local parts place and grab a helms or Haynes manual cause these aren't the only torque values and sequences you'll need if your building an engine!
Rod bolt torque is critical as is the main bolts torque. You will also need the head bolt torque, oil pan, pickup, etc.
Old 08-10-2011, 05:45 AM
bigwheel1983's Avatar
and make sure you take the torque up 1/3 at a time to do it properly
jimmyjun0213
Acura TSX
06-14-2015 09:15 AM
ray.riddler92
07-27-2011 05:07 PM
onwisconsin81
04-05-2010 01:25 AM
DaveF
02-07-2006 04:00 PM
tvrsir
08-08-2004 11:56 PM
Quick Reply: torque_spec_question
