freeze plug help integra
Old 11-26-2007, 08:51 AM
type Gendy's Avatar
Default freeze plug help integra
Hey guys i'm trying to figure what size freeze plug i need to get for the back of my ls vtec where the black box was. I couldnt find one solid answer , with people claiming i need anywhere from a 34.3 - 35mm. I have tried a 34.3 which was too small and a 35 which was too big. I cant find anyplace local that has a plug inbetween those two sizes. Anybody know what the ls block takes for sure?
Also, would you guys install this with hondabond or somethign to make sure it stays put and doesnt leak?
Modified by type Gendy at 2:33 PM 11/26/2007
Old 11-26-2007, 10:34 AM
type Gendy's Avatar
Default Re: freeze plug help integra (type Gendy)
ttt
Old 11-26-2007, 10:37 AM
Hardedge's Avatar
I don't know about size but you should be able to find that info in a service manual if you can get your hands on one.
Old 11-26-2007, 10:45 AM
type Gendy's Avatar
Default Re: (Hardedge)
didtn think to check in there, i have 2-3 of them but none for an integra
Old 11-26-2007, 08:28 PM
type Gendy's Avatar
Default Re: (type Gendy)
anybody?
Old 11-28-2007, 04:09 AM
type Gendy's Avatar
Old 11-29-2007, 03:15 AM
type Gendy's Avatar
Old 12-01-2007, 07:18 PM
type Gendy's Avatar
Old 12-20-2007, 09:58 AM
mitsuman's Avatar
Old 12-20-2007, 10:22 AM
pdiggitydogg's Avatar
I have used 34.3mm plug on 3 different LS blocks - all fit just fine....?
Old 12-20-2007, 10:54 AM
Luserkid's Avatar
Default Re: (pdiggitydogg)
Small piece of aluminum shaped to fit with some JBweld worked great for me
Old 12-23-2007, 06:54 PM
FastAsleep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy &raquo;</TD></TR><TR><TD CLASS="quote">didtn think to check in there, i have 2-3 of them but none for an integra</TD></TR></TABLE>
i checked my DA integra manual and found jack. Do you have a vernier?
Old 12-23-2007, 06:57 PM
FastAsleep's Avatar
Default Re: (FastAsleep)
also... maybe this is a last resort option but: http://www.rpmmachine.com/freezeplugsindex.shtml
Old 12-27-2007, 02:39 PM
mitsuman's Avatar
its 34.3. i just did mine (gsr) and it fit nicely. you have to hammer it in so it should be a little tight.
Old 12-27-2007, 03:06 PM
There ARE times where the hole is too large for the 34.3 plug - I talked to Earl and he uses 35mm plugs regularly (pounded).
Already told this to the OP ~ just posting for reference
Old 12-27-2007, 03:15 PM
slow_cx's Avatar
Get the right size plug and that should not leak. I've never used any sealant on any freeze plug i've done and they have worked just fine.
Old 12-27-2007, 03:58 PM
FastAsleep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">There ARE times where the hole is too large for the 34.3 plug - I talked to Earl and he uses 35mm plugs regularly (pounded).
Already told this to the OP ~ just posting for reference</TD></TR></TABLE>
the OP starts off by saying that he has tried both.
Old 12-27-2007, 04:21 PM
Yes, I read... I talked with him, as stated.
35mm has to be used.
Freeze the plug, heat the block w/ a torch - it will fit if 34.3 is too small.
[unsubscribing from thread]
boostedgsr1234
03-21-2008 05:09 PM
type Gendy
02-05-2008 09:51 PM
Sic_DA_Nine
09-05-2006 10:41 AM
mugenracer
06-16-2006 02:02 PM
TurbothisLS
09-22-2002 11:25 AM
Quick Reply: freeze plug help integra
