Flex seal rubberized stop leak in a can! - Honda-Tech
Old 03-05-2012, 12:27 PM   #1
delsolo95's Avatar
Default Flex seal rubberized stop leak in a can!
link: http://www.youtube.com/watch?feature...&v=0wHGYzHygzY
has anyone tried this on their weather stripping? i was thinking about buying this and spraying it on my 15-17yr old targa top seal. or is it a bad idea? lmk
delsolo95 is offline   Reply With Quote
Old 03-05-2012, 12:35 PM   #2
The Grumpiest
grumblemarc's Avatar
Default Re: Flex seal rubberized stop leak in a can!
Try it and report back. Be a pioneer!
grumblemarc is offline   Reply With Quote
Old 03-05-2012, 12:39 PM   #3
delsolo95's Avatar
ill see since they have a "as seen on tv" store couple miles away from home. i got a mad leak on both sides of the targa top towards the top middle of the window and also leaking from the trim on the a pillars. since its only 15bucks ill give it a shot today.
Old 03-05-2012, 12:54 PM   #4
O.G. triple O.G.
NVturbo's Avatar
ghetto rig methods.....leads to GHETTO RIG looking results.
Hence my sig.
NVturbo is online now   Reply With Quote
Old 03-05-2012, 01:01 PM   #5
Save some money and get some underbody sealant.
motegicivic is offline   Reply With Quote
Old 03-05-2012, 01:18 PM   #6
78F350's Avatar
If you want to "recondition" the seal, use silicone or 'dielectric' grease.
http://www.ebay.com/itm/Genuine-Hond...item5d2fdea1d2
Or the same thing in a bigger package:
http://cgi.ebay.com/ws/eBayISAPI.dll...id=p3286.m1934
If your seal is already trashed, spray away, but test it on a neighbor's car first.
78F350 is offline   Reply With Quote
Old 03-05-2012, 01:25 PM   #7
redm3turbo's Avatar
This is one of those times when I think you should just replace. Old rubber no matter what you do to it is a band aid at best.
Wasting money on products to just pay for the part later on.
redm3turbo is offline   Reply With Quote
Old 03-05-2012, 02:01 PM   #8
delsolo95's Avatar
Quote:
Hence my sig.
If you want to give me 600 + dollars to buy just two new seals (+ 2 more for the targa and then some clips) then paypal me some money. this is a temp repair until i get new ones. How is this ghetto rig?
Old 03-05-2012, 02:09 PM   #9
This stuff replaced the entire gasket on old sunroof, and looks great when it's dry. My buddy claims he patched a tire with it (Not sure until I try it myself, but based on the quality I wouldn't doubt it. I'll be going over my whole car with it this summer before a full body line-x. paid $13/can at dollar general, well worth it. It responds to sanding very well once dry too. and waterproof tight seal.
Count on a permanent fix though, as it doesn't wash off easily.
SykoFerret is offline   Reply With Quote
Old 03-05-2012, 02:14 PM   #10
I was thinking about doing that too. I carry tools in my trunk and they're all starting to rust. Wouldn't be a permanent fix just something to stop it until I could afford a proper fix. Lemme know how it works out for you.
Bakado is offline   Reply With Quote
Old 08-10-2012, 07:10 PM   #11
habanerored06si's Avatar
Any update?
Just purchased this and was planning on going this route.
Already bought the Flex Seal and thought about using a food coloring with water to see where the water leaks.
habanerored06si is offline   Reply With Quote
Old 08-10-2012, 08:24 PM   #12
You can get the same stuff made by rustoleum for 5 bucks at homedepot
Hidenplanvew is offline   Reply With Quote
Old 08-10-2012, 09:11 PM   #13
Fs: Honda del sol trga top seals / door seals NO LEAKS! redef90si For Sale 11 12-30-2015 05:29 AM
Act of Valor: Real USN SEALs with actors...epicness Johnny. General Discussion and Debate 113 11-02-2012 02:42 PM
drive axle seals part number? Crxmick Honda CRX / EF Civic (1988 - 1991) 2 05-21-2012 04:19 PM
Shaft Seal Retainer - A Better One!!! canaccord Honda Accord (1990 - 2002) 6 11-27-2007 08:31 AM
Is the rear main seal, the same as the crankshaft seal?? 91crxturbo Tech / Misc 2 09-01-2006 10:38 PM
Tags
1996, dollar, flex, flexi, flexseal, general, honda, leak, onda, rubberized, seal, spray, stop, tech, trunk, underbody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
