flat spot through 1000 rpm - 3000 rpm , please help
Old 11-10-2006, 12:29 PM
ek jordan's Avatar
Default flat spot through 1000 rpm - 3000 rpm , please help
i currently own a 2000 honda civic vti - ek4 - b16a2 loving the car to bits but the problem im experiecing is a flat spot between 1000 rpm-3000 rpm , its very VERY flat off the line ,up hills , it only happen when u put you're foot down about 1/4 way of the distance of the pedal , u can actualy feel the just jump back into life after the 3000rpm mark , a tps sensor or map sensor perhaps , has anyone experienced this problem , PLEASE HELP i keep getting left behind at the light ..!!!!
Old 11-10-2006, 01:20 PM
been there done that
doood's Avatar
Default Re: flat spot through 1000 rpm - 3000 rpm , please help (ek jordan)
it's called not having any torque
Old 11-10-2006, 01:25 PM
B18B1_4DR's Avatar
Default Re: flat spot through 1000 rpm - 3000 rpm , please help (that one doood)
my ls swap is doing the same thing right now, can't put a finger on it. My immediate thought was that it was fuel related so I purchased a new fuel filter, and ran some injector cleaner through it, but it's still there. Not sure. So I'm IN for this.
Old 11-10-2006, 01:31 PM
ek jordan's Avatar
well im in england , london and over here thats what we call it , TORQUE , lOl ,
Old 11-10-2006, 01:40 PM
ek jordan's Avatar
Default Re: flat spot through 1000 rpm - 3000 rpm , please help (B18B1_4DR)
b18b1 - ive had a new fuel filter , spark plugs , ht leads , msd rotor i run it shell optimax and have also various fuel cleaning products but still have no luck , its only slight flat spot , i can really feel it real bad at about 2700rpm 3000rpm anything after that it's fine
and for the IDIOT , im in london - england ,thats what we call it , TORQUE lOL .. GO AND SUCK DUDE ..!!!!!y%$
Old 11-10-2006, 04:01 PM
f20bej1's Avatar
tune up maybe
Old 11-10-2006, 07:02 PM
mr nut's Avatar
Default Re: flat spot through 1000 rpm - 3000 rpm , please help (f20b eg)
i alos have the same problem but i have no clue what it is
Old 11-10-2006, 07:14 PM
HT White Ops
Eran's Avatar
The problem is having a B16A. They're gutless.
Old 11-11-2006, 06:17 AM
electric-boost's Avatar
check your timing, my distributor was retarded all the way when I purchased my car and ran like it was dead untill 3500rpm then it came to life. Then I adjusted it and it ran 10x better.
Old 11-11-2006, 08:59 AM
ek jordan's Avatar
yea i know the b16's are quite gutless downlow ,
i have checked the timing twice , all timing marks line up perfectly , marks on the camshaft pulleys line up and so does the crank pulley , i mean if the timing was out , the car would not run very nice and u WOULD know if the timing was out , i personaly dont think the timing is out , its just hesitating down low ..! a TPS or MAP sensor mayB ...?
fyjimo_jr
02-04-2015 10:33 AM
04silvep3
21
10-19-2008 04:54 PM
K4Life
10-11-2007 11:52 AM
The G2 Racer
11-06-2002 03:29 AM
Quick Reply: flat spot through 1000 rpm - 3000 rpm , please help
