Fitv wont stop sucking air.= [
Old 08-04-2010, 07:08 PM
Omega Blaze's Avatar
Default Fitv wont stop sucking air.= [
I recently installed a skunk 2 manifold and now i have high rpm at idle. (With the throttle cable unhooked-2k rpm)
Everything was fine before i installed the skank2.
When i cover the fitv hole in the throttle body, it idles down to normal.
I bypassed the fitv hoses.(one hose from the intake manifold to the iacv)
and blocked off the fitv with gasket paper. (Underneath the T.B)
Why does this **** keep sucking!= [
Old 08-04-2010, 08:43 PM
D16SiHatch's Avatar
Default Re: Fitv wont stop sucking air.= [
have you tried taking it apart and seeing if it the thermowax plunger has backed out any?
http://www.team-integra.net/forum/di...g+Common+Topic
Old 08-04-2010, 08:49 PM
MiG-21 superfan
builthatch's Avatar
sounds like a TB gasket issue or IM flange issue. isn't the pathway for that hole sealed up against the IM flange? i can't remember.
Old 08-04-2010, 08:52 PM
yep..
turned all the way in..
but that shouldn't even matter if i blocked the fitv off= [
i also bought a new tb gasket today..
i noticed that the tb gasket is a lil smaller than the im opening.
but that shouldnt affect idle like that..
thewrai6th
09-13-2011 05:19 PM
1989sircrx
10
03-27-2010 04:26 PM
emooheo
02-24-2008 04:54 PM
matto2413
06-01-2005 11:36 PM
se93
12-28-2003 09:21 AM
Quick Reply: Fitv wont stop sucking air.= [
