Firing Order
Old 05-22-2008, 04:05 PM
BiG_DeE's Avatar
Default Firing Order
So i was installin radio in dark last night, pulled the wrong fuse i pulled the fuel pump thinking it was stereo and so when car wouldnt start i thought maybe the firing order was off, so i took out wires and changed the order, now im stuck because i cant seem to get my car to run correctly, the cap looks good, and ive done the firing order my chilton's manual says as well as what everyone says on HT, but still cant figure it out. heres how i had it when i got the car running so i could drive into garage, but ran realllly crummy and died 2 times goin up the minor hill to get into my garage.
4 3 2 1
3 4
2 1
Old 05-22-2008, 05:20 PM
elektronsi's Avatar
Default Re: Firing Order (BiG_DeE)
if you are facing your motor the left most cylinder is #4 couting down moving right, so your right most cylinder would be #1, and the firing order is 1-3-4-2
and on your dizzy it will be
it turns clockwise from the point where 1 is
Old 05-22-2008, 05:26 PM
* B A N N E D *
ReactioN's Avatar
Default Re: Firing Order (elektronsi)
dose this go for all engines?
Old 05-22-2008, 05:51 PM
blwn95civic's Avatar
Default Re: Firing Order (ReactioN)
https://honda-tech.com/zerothread?id=2078334
Search button is your friend
Old 05-22-2008, 06:06 PM
EX-T's Avatar
Default Re: Firing Order (blwn95civic)
Also try http://www.autozone.com
Old 05-22-2008, 06:20 PM
BiG_DeE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blwn95civic &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=2078334
Search button is your friend </TD></TR></TABLE>
read my post, i did search, also i didnt pay attention to the flat part on the dizzy because d series dizzys arent put in same way that b series are.
Old 11-09-2019, 07:00 PM
Reggs805's Avatar
Hi I’m having an issue with my 97 Honda Civic ex I just replace distributor spark plugs and wires . My car will not start on it’s original firing order but it will start with firing Order 4213
Help !.
It runs fine but idles ruff at a stop like if it’s miss firing and when I turn it on it coughs and stutters and acts like it’s gonna turn off but it stays on shaking idling ruff ... any help is greatly appreciated.
Old 05-19-2021, 09:37 AM
Louie Ramos's Avatar
4 3 2 1
3 4
2 1
does this apply to the Honda civic 1994 as well
Old 05-19-2021, 01:25 PM
muellersfan's Avatar
JDM_SOHC
11
12-29-2019 08:52 AM
wwolf771177
07-15-2018 06:33 AM
Jtmvtec
11-28-2015 11:02 AM
rudeboy
05-07-2008 05:32 AM
Qwikrex
12
03-16-2003 10:57 AM
Quick Reply: Firing Order
