Finally did my 'Fender Swap' - how-to DIY type post - Honda-Tech
Old 01-27-2006, 11:19 PM   #1
B A N N E D
Default Finally did my 'Fender Swap' - how-to DIY type post
Ok, so I posted about it before and I finally got it all done. I don't know if I took enough pictures but I'll show what I got.
Ok there's alot to do before just pulling the fender off so make sure you have some time. I'd give yourself maybe 4 hours if you don't have all the right tools, lighting, experience, etc.
So lets say your friend was driving your car. There's snow tires on the front, but he decides to drive around corners in a spirited fashion anyway. Around the turn, he hits some wet spot and hits a dump truck. Now, this is where you are.
and here
and the impact broke off the side view mirror too, so now you have JDM units that don't match - gotta love that inspection sticker!
To do this w/o messing up paint, I recommend a medium phillips head screwdriver, a 10mm 6pt socket with a 10" extension, a ratchet, and a ratcheting 10mm combination wrench. Oh and wire cutters to cut naughty fasteners.
So if you're sick of the corner light not fitting right and of course the unsightly dent in your front left fender, it's time to change it out! If you've got any other stuff to do, like run wires from the door to the car, install headlights, corner lights, bumper pole, or side markers, I'd do it now. Also, if your hood latch cable is broken or something, you'll be able to see it when the fender is out of the way. I won't give any more detail than that as I know it's a sensitive subject.
There's no real order, but the following need to be done.
Remove the screws at the leading edge of the fender liner. They're mostly plastic and should unscrew easily. If they just turn but don't come out, cut them with wire cutters and remember to get a new one later.
Remove the screws that hold the fender liner to the side skirt.
Remove the screw fasteners that hold the side skirt on. Same thing. IF they won't come out, cut it and remember to get one of these too.
Once the screws are all out, slide the sideskirt forward. You may have to 'hit it from the back' (of the car) with the palm of your hand or some other soft, blunt object. You need to jar it loose for it to slide forward. (I forgot this step and just ripped it off and ended up breaking some of the clips.
Remove the three 10mm bolts seen in this picture - one may be partly hidden by the rubber seal at the top of the image.
Remove the pin from the door hinge- the one that prevents the door from going out too far. You need to gently hyperextend the door to get to these 10mm bolts-
there are 2 in the door jam area. One is below the A- pillar and the other is just above where the side skirt was.
There is also another 10mm bolt at the bottom edge of the fender where the side skirt was.
There is a 10mm bolt in here. I couldn't take a pic when it was on, so this will have to do.
Also remove the screw that goes through the white 'jaunt' seen in the middle of the above picture.
Double check that you didn't miss a screw or bolt and the whole fender should be loose now. Close the door, lift the fender up and rotate towards the back so the tabs come out clear, and that should be your newly freed fender!! Remove the side molding from the back and stick it on your new fender.
Installation is reverse of removal, but be sure to transfer all the screw-tabs or fasteners if your new fender didn't have them.
TO LINE UP the fender is quite difficult. I'd say get all the 10mm bolts started (except for the one thats a pain in the *** to get to, the one directly behind the turnsignal) and shut the door and hood. IF your gaps are unsightly, fix it! push or pull the fender into the position that looks best and tighten the closest bolt. If you need to move it back to fit with teh door better, tighten the top bolt (in the door jam area) first, then the bottoms.
If you needed to run wires from the door to the car, this plug pops out fairly easily allowing just that.
While the fender is off, I decided it would be the easiest time to put on my JDM headlights so I did all the wiring and such with the fender off, but when I did the other side, it really wasn't any harder, so it really wasn't necessary.
I also tried my hardest to get the alignment right, but I'm not satisfied with it, so I think I'd like to take the car to the Honda body shop and have them line it up. I know it isn't very DIY but it's hard to do even with help.
99CivicSiBrian is offline   Reply With Quote
Old 01-27-2006, 11:23 PM   #2
amej8's Avatar
Default Re: Finally did my 'Fender Swap' - how-to DIY type post (99CivicSiBrian)
Quote:
happens everyday . would seem to be a very easy DIY even for car noobs but still good stuff to post for the lazy ones who dont like to figure things out on their own
amej8 is offline   Reply With Quote
Old 01-27-2006, 11:26 PM   #3
B A N N E D
Default Re: Finally did my 'Fender Swap' - how-to DIY type post (amej8)
Quote:
Yeah I figured for the guy who thinks he has to pay $300 for someone to put it on, just DIY and keep the dough. I guess I could rattle can it and it would look aight. I'm still uploading pics of the finished product.
B
Old 02-12-2006, 01:18 PM   #4
eg6r4eva's Avatar
eg6r4eva is offline   Reply With Quote
Old 02-12-2006, 02:15 PM   #5
alacard's Avatar
anyone know if this is the same for an ek?..i have the same problem
alacard is offline   Reply With Quote
Old 03-15-2006, 10:47 AM   #6
Cory Matthews's Avatar
Default Re: (alacard)
freakin awsome.
Cory Matthews is offline   Reply With Quote
Old 03-15-2006, 11:00 AM   #7
5lugSlug's Avatar
if you dont know how to replace fenders on a civic.. you probably shouldnt have a tool set
i cant swap fenders faster then i can change my oil
5lugSlug is offline   Reply With Quote
Old 03-16-2006, 10:06 PM   #8
Default Re: (EJacul8)
were you born knowing how to change a fender? people got to start from somewhere.
Old 03-16-2006, 10:56 PM   #9
Out of every
Default Re: (aallbbeerrtttttt)
haha did the same thing when i replaced my fender on my old sol. didnt know it slides out
Out of every   Reply With Quote
Old 03-16-2006, 10:59 PM   #10
Voyage34's Avatar
Default Re: (e gee two)
nice writeup
Voyage34 is offline   Reply With Quote
Old 03-17-2006, 04:01 AM   #11
gsp em1-g35's Avatar
Great step by step instructions!
gsp em1-g35 is offline   Reply With Quote
Old 06-22-2007, 10:10 PM   #12
Highlifer's Avatar
Default Re: Finally did my 'Fender Swap' - how-to DIY type post (gsp em1)
while ur in there u might want reroute ur hood release cable to inside the engine bay, I heard thieves will reach in behind the wheel well liner to release the hood.
Highlifer is offline   Reply With Quote
Old 06-22-2007, 10:13 PM   #13
punoy69's Avatar
Default Re: Finally did my 'Fender Swap' - how-to DIY type post (Highlifer)
yea, should have told him that a year ago.
way to bump a year old thread
punoy69 is offline   Reply With Quote
Old 11-05-2009, 08:04 PM   #14
92lxsleeper's Avatar
4 hours????
damn. i did mine in 15 minutes lol
92lxsleeper is offline   Reply With Quote
Old 11-05-2009, 08:34 PM   #15
Quote:
Originally Posted by 92lxsleeper View Post
4 hours????
way to bring back a 2 year old thread dumb ***
bar'dh22 is offline   Reply With Quote
Old 11-05-2009, 08:37 PM   #16
geneeunit's Avatar
4 hours????
and it took you under a minute to bump a thread from 1/27/2006
are you serious?
geneeunit is offline   Reply With Quote
Old 06-14-2011, 04:31 PM   #17
nice write up.
ps. it would be hilarious if someone else would bump this thread yet again.
oops...
Fredm2 is offline   Reply With Quote
Old 06-14-2011, 04:58 PM   #18
nice ttt
Capitol Built is offline   Reply With Quote
Old 08-14-2011, 03:08 PM   #19
Texas4door's Avatar
Just to be hilarious...
*shot*
Nice write up though
Texas4door is offline   Reply With Quote
Old 02-23-2012, 03:02 PM   #20
bigpunn421's Avatar
thanks for the post. its going to help me alot
bigpunn421 is offline   Reply With Quote
92 front fender removal how-to with pictures ced715 Honda Accord (1990 - 2002) 0 10-20-2016 07:49 PM
alot of em1 b16 and misc parts for sale. CHEAP. head, block, brackets, lines etc. spidermancivic Southern California (Sales) 32 06-20-2008 03:10 PM
Type R vs. non-R side skirts: debunking the myth PatrickGSR94 Acura Integra Type-R 17 07-18-2007 07:45 AM
Upper Ball Joint How To DIY: uneek4dr Honda Prelude 15 03-12-2006 06:39 AM
DFW: $10 Parts Blowout!!! Prefer Pick-up (da, zc, b16a, b18c, b18a) Cjsls For Sale 10 09-07-2004 10:56 PM
Tags
1988, 1990, change, civic, clip, fender, g35, honda, liner, needed, prelude, remove, replace, replacing, screws, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
