fault code #10 IAT SENSOR - Honda-Tech
Old 06-23-2008, 07:30 PM   #1
ekcoupe00's Avatar
Default fault code #10 IAT SENSOR
i just recently got this fault code. i had never had this fault code ever since i swap the motor and it's been about 3-4yrs now. i have a 96 gsr in a 2000 ek coupe with obd1 harness. i checked the code and that's what i came up with code # 10. the car doesn't idle funny and the performance is ok. with any feedback asap would be greatly appriciated thanks.
ekcoupe00 is offline   Reply With Quote
Old 06-23-2008, 08:39 PM   #2
v8 integra's Avatar
Default Re: fault code #10 IAT SENSOR (ekcoupe00)
change the sensor..its like 15 bucks from honda ...idle air temp sensor..and also check the voltage of the wires...and b4 buying a sensor i would reset the ecu and c if it comes back on..if it does then buy the sensor if ur getting the proper voltage..if u searched around u will find how many volts u should b getting..
v8 integra is offline   Reply With Quote
Old 06-23-2008, 08:45 PM   #3
SovXietday's Avatar
Default Re: fault code #10 IAT SENSOR (v8 integra)
Quote:
Ey.
It's about $50 from Honda. It's called the Intake Air Temperature sensor. The part should be on the back of your intake manifold, oval in shape with two screws, 2 wire plug.
SovXietday is offline   Reply With Quote
Old 06-23-2008, 09:28 PM   #4
H-T White Ops
Frozen E's Avatar
Default Re: fault code #10 IAT SENSOR (SovXietday)
You sure about that? I thought the IAT sensor was the one that plugs into the rubber grommet.
Frozen E is offline   Reply With Quote
Old 06-24-2008, 11:01 AM   #5
v8 integra's Avatar
Default Re: fault code #10 IAT SENSOR (IslandSi)
sorry!! i didnt mean idle..its the first thing that came to my head..idk why.... and yes depending on ur car..its either on a intake arm or the intake manifold..
and i got my iat sensor for around 15 bucks up in nj's honda dealer =]
Old 06-25-2008, 08:19 AM   #6
Rease3's Avatar
$15 at the norristown honda dealer
Rease3 is offline   Reply With Quote
Old 06-25-2008, 08:46 AM   #7
* B A N N E D *
Quote:
that would be your "EGR" valve.
don't ask me how, it blew my [freak]in mind when i saw that ****.
minime-civic is offline   Reply With Quote
Old 06-25-2008, 09:43 AM   #8
H-T White Ops
Frozen E's Avatar
Default Re: fault code #10 IAT SENSOR (minime-civic)
I know what an EGR valve looks like, and no, that's not what I'm talking about.
Old 06-25-2008, 09:54 AM   #9
H-T White Ops
Frozen E's Avatar
Here's the air intake temp sensor on an EM1
Old 06-25-2008, 10:00 AM   #10
* B A N N E D *
he said he's running OBD-1
so gtfo with ur OBD-2 business.
Old 06-25-2008, 12:20 PM   #11
Dyce's Avatar
i got the same car with the same problem =$.
Dyce is offline   Reply With Quote
Old 06-25-2008, 01:27 PM   #12
H-T White Ops
Frozen E's Avatar
OBD1 computer with OBD1 adapter harness....sure
But he's running an obd2 engine. All the sensors are still int he same place.
So now YOU gtfo.
Old 04-24-2009, 05:14 PM   #13
.Hatches.'s Avatar
any updates, I have the same code on a h22. never had this problem until recently
.Hatches. is offline   Reply With Quote
Old 08-31-2009, 06:39 PM   #14
eggsi619's Avatar
bump this to the top... ive resested the ecu and changed the sensor and still no answer... what happens is my cel will go off and my car will be running funny and when its on it seems to a little better with the cel on. when i give it gas, and the sensor goes off, and when i gas it itll loose power.
eggsi619 is offline   Reply With Quote
Old 09-01-2009, 03:19 AM   #15
skaternak's Avatar
Quote:
iat stands for intake air temp, not idle air temp...
skaternak is offline   Reply With Quote
Old 01-30-2011, 01:50 AM   #16
gamakichi77's Avatar
anyone can post pic where is the location of the IAT sensor for OBD1?...i'm getting code #10 as well.
gamakichi77 is offline   Reply With Quote
Old 01-30-2011, 05:55 AM   #17
Technical Hero
HondaPartsHero's Avatar
For every honda/acura (at least up to 2000) engine with the exception of the 96-00 Honda Civics (including the B16A2 in the Si) it bolts to the intake manifold. Like this some where either on the back, front or one of the runners. The sensor will either be black or white:
The 96-00 Civics look like this:
HondaPartsHero is offline   Reply With Quote
Old 03-29-2012, 08:10 PM   #18
I have a code 10 and 16 (16 I think is just to reset ecu,so I've heard). I have a 91 civic with a stock replacement d15b2. does anyone know where the iat sensor is on it? There's like 3 plugs going into the intake manifold, and none on the intake arm. I just dont know which one it is, ii looked around the internet but couldnt find anything. Thanks in advance!
NoName487 is offline   Reply With Quote
Old 04-07-2014, 01:27 PM   #19
believe it or not i had the same problem code 10 IAT sensor on my 93 civic eg with stock p28 ecu and b20vtec/b16a engine in it. I found that i mixed up the 2 plugs- knock sensor and IAT. I switched them around and it worked great!!! time to test n Tune
P.S. i used a b18c gsr engine harness and needed to extend some wires but that was all
mgrandmaison1 is offline   Reply With Quote
Old 04-10-2014, 06:05 PM   #20
existanzcivicb20's Avatar
I think the IAT sensor he needs is a DOHC IAT not a SOHC that you can get from the honda dealer for $15(thats the one that goes on the intake pipe) he need the one with the two screws that runs about $50-$75
existanzcivicb20 is offline   Reply With Quote
Old 06-02-2014, 11:39 AM   #21
Icon2 Re: fault code #10 IAT SENSOR
i know this is a super old post but im wondering what are the ohms and voltage i should be getting from the wires at the pigtail to the iat and what it should be at the plug with engine off an cold or warm ect. any help is greatly appreciated
dillenbeck518 is offline   Reply With Quote
Old 12-18-2014, 12:45 AM   #22
nexgen91's Avatar
Quote:
You prob already have it but just in case someone else needs it, here is the troubleshooting steps for IAT for B Series:
https://www.dropbox.com/s/bawmq6gd4g4mf47/IAT1.png?dl=0
https://www.dropbox.com/s/zyuwf9pymbj3zbl/IAT2.png?dl=0
nexgen91 is offline   Reply With Quote
98 2.3CL: Transmission Solenoid Codes, Slow Acceleration, Alternator Died UWMU Honda Accord (1990 - 2002) 15 12-19-2015 10:40 AM
obd1 fault code help h22integra.eire Engine Management and Tuning 2 09-14-2015 07:08 PM
2003 CRV Flashing D Drive P0700 Transmission Fault buttercup Honda Element & CR-V 3 08-09-2015 07:39 AM
p1298 Code - Intermittent ELD Issues? Ryan-R Acura RSX DC5 & Honda Civic EP3 0 03-06-2015 11:28 AM
2000 gsr fault code 420 coffeyface2000 Acura Integra 4 02-07-2015 04:18 PM
Tags
10, 91, acura, b16, civic, code, codes, honda, iat, integra, location, obdo, pictures, sensor, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
