fast idle valve - Honda-Tech
fast idle valve
Old 06-18-2009, 03:49 PM   #1
eglude's Avatar
Default fast idle valve
so i have a 95 civic hatch with a d15b, i picked up a p32 intake manifold (d16z6 manifold) i go to hook everything up and the hose that goes from the bottom of the fast idle valve has no where to hook up on the intake manifold. this **** sucks. how do i go about fixing this problem? thanks in advance
eglude is offline   Reply With Quote
Old 06-18-2009, 04:45 PM   #2
eglude's Avatar
Default Re: fast idle valve
bump for help
Old 06-18-2009, 05:08 PM   #3
D16SiHatch's Avatar
it starts at a L shaped hose at the intake manifold, and from there it moves through a metal tube to another hose which then goes to the inlet of the fitv. after leaving the fitv it goes to the iacv. once leaving the iacv it drops down and connects to the coolant pipe on the back of the block.
D16SiHatch is offline   Reply With Quote
Old 06-18-2009, 05:35 PM   #4
DjGuamstyles's Avatar
Nice diagram above. I heard, some drag racers bypass the FIT-V so the intake manifold temperature is lowered.
DjGuamstyles is offline   Reply With Quote
Old 06-18-2009, 05:44 PM   #5
yes thats what i would do because its pointless if u live in warm climates. just by pass the tb and run the lines to ur iacv. ebay acually makes block off plates b/d/f/h all fit
apexi_rsx is offline   Reply With Quote
Old 06-18-2009, 05:58 PM   #6
eglude's Avatar
thanks, this is going to help a lot! where did you get this diagram from?
Old 06-18-2009, 06:44 PM   #7
civic_driver's Avatar
probably from the service manual
civic_driver is offline   Reply With Quote
Old 06-18-2009, 10:34 PM   #8
D16SiHatch's Avatar
Quote:
i cropped out a picture i retrieved from AllData. I have a dealership login :D
then with the help of mspaint i added the awesome red lines and numbers lol
Old 09-14-2012, 12:53 PM   #9
This is so helpful I just did the exact same thing but my throttle cable doesn't mount right so it either to tight or too loose. Why?
GSRicky37 is offline   Reply With Quote
skunk2 intake/throttle body install. waynesumner All Motor / Naturally Aspirated 27 02-18-2017 07:09 PM
Intake/Throttle body help KHANV1CT Honda Civic / Del Sol (1992 - 2000) 4 05-09-2014 09:13 PM
96' civic ex cooling hose diagrams dillon410021 Honda Civic / Del Sol (1992 - 2000) 2 06-14-2009 06:34 PM
important question mugenpovver Honda Civic / Del Sol (1992 - 2000) 2 12-04-2008 06:16 PM
Where is the Fast Idle Thermo Valve? comptechgsr2000 Acura Integra Type-R 4 05-13-2002 10:15 PM
Tags
1992, b18b1, back, block, civic, coolant, d16y7, diagram, fast, fixing, honda, hose, idle, intake, manifold, si, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
