FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up (56k Goodbye)
#676
Re: FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up (56k Goodbye)
i keep hearing with the d15 bottem end and z6 head time is off 4 degs. that u need to run a y8 cam gear on the z6 head is this true
#677
Ok nice write up I need some help I'm currently working on the same project and I've got the motor all tore down to the block and I'm takin it to the machine shop next week to get honed and cleaned up any idea on pistons? I'm not building it to race its gonna be a daily driver but I know how it drove with the stock head and I just want some more power I was thinking maybe some high compression pistons and maybe a stage one cam not gonna change internals the head has already been shaved but I'm not sure how much was took off any suggestions???
#678
The Grumpiest
This thread is about simply swapping heads. Not about upping compression or changing out pistons. I would suggest looking into the All Motor forum but from MY research, you're wasting your time all the way around.
#680
Can anyone help me out with some info? I have a z6 head going on a d15b2 block and I need to know which exhaust manifold and downpipe to use.
#686
so overall what other effects did this have on your car other than a little bit better low end torque and the VTEC benefits? any difference in fuel mileage? tings of that nature.
fyi im not necessarily new to cars, i know a little bit, basics, just nothing about hondas, hence my joining this forum :D
edit: sorry, old thread i know..
#687
I'm doing a mini me right now I'm in the wiring part like the distributor, fuel injectors, and the ecu i was wondering if i can use a stock vtec manual ecu in a dx with the dx wiring all i would have to do it wire the vtec the same way i would with a chipped ecu right? could i do that, feed back pleaaase!.
#688
#691
#693
I'm doing the same swap except with a y7 head I just wanted to ask what p/s will I need? because my y7 P/S isn't bolting up right.
#695
I like the tuna here
#697
What do i need for ignition distributor? i cant use the stock d15b7 distributor on the z6 head? does it need a new cap or the whole thing?
#699
Does anyone know what timing belt i use on this conversion? D15b7 with d16z6 do i use the d15 on the bottom and d16 on top? Shaving of any of them?
#700
kinkyintegra
Northeast (Sales)
11-14-2008 08:53 PM
screen_name
02-01-2006 07:59 AM
