FAQ: Axle Replacement Tutorial With PICS!
#51
Re: Axle Replacement Tutorial With PICS! (B18C5-EH2)
wow actually that reminds me of my friend eric doing my tranny swap.. he took out the VSS I'm like wow i never knew you can do it that way.. for showing everyone that easy tip..
#52
Re: Axle Replacement Tutorial With PICS! (IM ALL BOB)
#54
I really don't know
Re: Axle Replacement Tutorial With PICS! (paragus)
i have something to add to write up #8 i believe. When hammering keep the castle nut on you do not want to miss while hammering and hammer off a few threads. Just keep the nut on enough the allow you to miss the threads incase you became like lightning (never striking the same place twice)
Good stuff, they should make a forum with threads such as this. post the tutorial and then lock it.
#55
New User
Re: Axle Replacement Tutorial With PICS! (TypeOne Enjoy It)
uhhhh i dont know if i removed the speed sensor or not because my gsr wont fill up through the speed sensor pictured.
edit: never mind I am an IDIOT. figured it out.
[Modified by Aeka GSR, 4:30 PM 1/20/2003]
#56
Re: Axle Replacement Tutorial With PICS! (Aeka GSR)
okay for those of you who dont have access to air tools or dont want to spend the $$$ for air tools heres a good deal that i found
http://www.harborfreight.com/cpi/cta...emnumber=45252
for 59.00 you get a 1/2" electric impact wrench here she is....trust me it will make your life a whole lot easeir and its cheap too and for $7.00dollars more you get a 1yr no questions asked warranty
#57
Re: Axle Replacement Tutorial With PICS! (TheRedSkoolingBus)
I never knew they made a electric impact wrench hahah that's crazy I guess it's good if you can't afford the compressor.. do u know anyone who has used one redskool?
#58
Good write up Tom. I found the trick on how to fill the tranny fluid up like that when I was working up at Honda. I will tell you this the guy that showed it to me was the Master Tech at the Honda Dealership I worked for. So to help with that ******* that is giving you a hard time. The Honda dealer shows other people this tip and even use it themselves.
#59
Re: Axle Replacement Tutorial With PICS! (13HYBRID20)
bump for goooood info.
I have a question my car shakes when I acelerate like you said how do I know if it's the right or left axle?
#61
Re: Axle Replacement Tutorial With PICS! (degooser)
this thread moves like the classified ads! bump for good info...there should be a how to - forum...where mods control it and add stuff like this on. pictures are the greatest!
#65
Re: Axle Replacement Tutorial With PICS! (showspeed.com)
I'm trying to break the 32mm nut and it's a bitch!
When looking at the nut there is a piece of metal that looks to bent in from the axle so the nut won't move. Do I have to bend that piece back out to remove the 32mm nut?
I'll post a pic if needed.....
#66
H-T Poker champion
Re: Axle Replacement Tutorial With PICS! (nfiedler3)
It's not very hard to do at all.. The turorial should make it cake for anyone. Good thinking Tom.
Although.. none of the pics seem to be working..
#67
Re: Axle Replacement Tutorial With PICS! (Hatchy-Ownzjo0)
yeah nice write up!
I've never removed the VSS to do this though. but whatever works, and makes it easier for ya.
#68
The axles were easy once I found a nice thick chisel and just pryed them out
#69
Re: Axle Replacement Tutorial With PICS! (Hybrid93Hatch)
One of the 32mm nuts was a bitch to get off. But after some sanding and beating with screwdriver / hammer and breaking one Craftsman screwdriver they were both removed.
#70
awesome write up tom!! i thought i was the only one doin the speed sensor thing. it makes it sooo much easier, but hey i might stop doin it cause its an extra step
haha anyways good info and i agree with the guy above that said a "FAQ" or "how to" forum would be awesome
#71
Re: Axle Replacement Tutorial With PICS! (all stock)
lifetime warranty on that craftsman. get it replaced for free..it's a handtool, right?
#75
ttt
oh and btw very nice job on the tutrial
