FAQ: Axle Replacement Tutorial With PICS!
#452
Re: FAQ: Axle Replacement Tutorial With PICS!
thanks so much for this tutorial. I didn't manage to break the ball joint loose by banging on it, but It did pop off with a cheap ball joint tool from princess auto.
Good tip on filling up the tranny from up top.
#453
Plan on changing right axle this weekend and this tutorial is excellent. TYVM
Only have one question. When refilling the tranny fluid why can't you just do it the usual way by adding it where the dip stick goes in ?
Thanks in advance,
MP.
Thanks in advance,
MP.
#456
#458
Premium Member
I didn't drain mine, it bleed a little down the transaxle but nothing significant. I didn't even need to top up after I was done, just clean up the transaxle case. I also torqued my axle nuts to spec which this write up doesn't even mention, they say make it snug which I don't agree with.
I also don't beat on the lower control arm to pop the lower ball joints, nor do I use the pickle fork. I learned another way that doesn't damage anything and works like a champ.
You can find the trick here:
Clicking noise on turns, some what on straigts, HELP - Honda-Tech
Thanks!
#459
I really like the idea of this trick, but I am unclear as to what/how the wrenches are seperating the ball joint from the LCA? Are you locking the wrenches on something in the subframe? And then when you lower the jack the coil over assembly is popping the LCA off the ball joint?
Thanks!
Thanks!
This is what I use now:
https://www.amazon.com/OTC-6297-Ball.../dp/B0015PN010
This video shows the trick I did before I got the separator. I just found you will bend metal so I stacked two wrenches together to have solid metal. A socket will bend as will the box end of a wrench. Notice how he is using the handle of his ratchet as it's solid metal to stick into the space while it's jacked up:
#460
Premium Member
I now use a ball joint separator (not the pickle fork) but for that trick, when you jack up the control arm the gap between the knuckle and the LCA widens. You slide a couple of wrenches in between right next to the ball joint and when you lower the jack the strut spring pressed the assembly down. The space tries to shrink but the wrenches prevent it and ultimately pop the ball joint free as the pressure builds while lowering the arm/knuckle assembly.
https://www.youtube.com/watch?v=ISY8bGof3bQ
#461
#462
Tomcat - I bought the same type of tool at Harbor Freight. When I had to replace my upper ball joints, I used the tool, and even with a nut left on to try to protect the threads, the threads ended up getting a little messed up where I had problems trying to get the nut off. The race shop that I go to just uses a hammer to hit the side of the joint to get them to separate, and I know that some of the ball joints or tie rod ends are smaller, and separate easier. Anyway, do you use the above tool for all three joints (upper and lower ball joints plus steering tie rod end), and do you have any problems with the threads getting messed up? Thanks!! - Jim
If I recall I used the smaller setting for the uppers and the tie rods as it keeps the lower jaw more level with the post. The large setting was only used on the lowers if I recall.
#463
I just used it on all three as I had to replace the knuckles on my car a couple of weekends ago. Didn't have any issue on uppers, lowers or tie rods.
- Jim
#464
Premium Member
#465
Former Moderator
Unreal that people are still using this to swap axles! I'm glad it's helped so many. The right axle in my wagon just started clicking, LOL!
#466
Seagull Management
No need to improve on perfection
#467
Great write up!
One thing is I couldn't get my ball joint loose, no matter how much I banged it. Any other way I can remove the axle without removing the lower ball joint? Thanks!
Whoops, sorry just saw the wrench in the ball joint space trick.
#469
#470
Should not hurt the joint, no. But it might tear the dust boot. Get an extra set of boots for around $3 each and you'll be set.
#472
Former Moderator
dynamo
13
11-14-2005 08:22 PM
