f swap in my soL..
Old 03-16-2008, 11:17 AM
yoRt's Avatar
Default f swap in my soL..
ok i have a few questions. first is that im thinking about doing an f22 single cam swap into my soL. why? because i want to stay single cam and i plan on doing all motor, plus i can get the whole swap for about 500 bucks. im not looking to do a b series or k, or h22, i want 2 stay n/a single cam. would doing this be the exact same as an h22 swap? would i need to do any frame mods? what all would i need from the donor accord? would i need the axles, wiring harness, and mounts? i know id need to cut out for the shifter assembly but waht about shifter cables? any info would be helpful. pZ
Old 03-16-2008, 11:27 AM
MrMug3n's Avatar
Default Re: f swap in my soL.. (yoRt)
yeah the casting for the tranny and the block are the same as the h22 or h23 so axels mounts and alot of moding. converting the shift linkage to a cabel linkage ext. not really worth it
Old 03-16-2008, 11:40 AM
bpkmrtoes's Avatar
Default Re: f swap in my soL.. (MrMug3n)
i always wanted to go f22.
Old 03-16-2008, 01:23 PM
prettylew's Avatar
yea its only 500 for the swap but then u need mounts and labor, and your axle angles will be ALL F'D up. all for a freakin honda accord motor.
so 500 for swap.
then another 700 for misc parts and brackets and other bullshit to get it all to work
you can get a VERY capable GSR or B16 motor for that much
with so many OTHER options out there. and GSR swaps going for cheaper prices everyday.
WHY would you want an F22 swap?
sometimes "different" isnt always good. look at emo people lol.
Old 03-16-2008, 03:12 PM
nix94delsol's Avatar
Default Re: (prettylew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew &raquo;</TD></TR><TR><TD CLASS="quote">
because MAYBE spending 500$ on a motor is a better idea than spending 3500$ on the same amount of power
and look at the specs for an F22, put an H23 transmission on it and run with a GSR for a fraction of the price
youll also need a b series shift linkage with a B series del sol, and wont with an F series
OP, search for H series into an Eg, its the same thing
Old 03-16-2008, 06:11 PM
yoRt's Avatar
Default Re: (nix94delsol)
thats exactly how im thinking about it, if i did b, i would do b20v, so say 500 for motor, 500 for head and a g for the tranny, if i did the f22, i would do all the labor myself, ive takn machining for a year, 3 years of metal fabrication/custom fabrication, so id spend 500 on the whole swap from a donor accord, buy an h22 tranny for 200, and then mounts. i dont think that money wise, that this will cost alot. i like single cams because parts are cheap and they are underdogs. would i need the whole engine wiring harness from the donor accord? or could i use the one from my car. i have a 96 del sol s, it has a 5spd d16y7 non-vtec.
Old 03-16-2008, 06:23 PM
16yroldekownr's Avatar
Default Re: (yoRt)
its crazy that i'm finding this. cz the other day i was thinkin about a f22 swap in my ek. i know exactly how you feel about the n/a single cam . if you decide to go on with it. show me some progress....
Old 03-16-2008, 06:30 PM
yoRt's Avatar
Default Re: (16yroldekownr)
defly will, defly thinking about this. i need more opinions on what all id need.
Old 03-16-2008, 06:49 PM
awdgsx96's Avatar
Default Re: (yoRt)
I think the user redstandardzchatch or something like that did an F22 swap into an EF. If you look through his threads you might find some stuff that will help.
The F22 is a really low compression motor, if you wanna stay N/A and make some power youll probably want to look at new pistons or something. Bisimoto is a reputable company I can name off my head that makes a more agressive cam for the F
Old 03-16-2008, 07:10 PM
96 EX's Avatar
Default Re: (awdgsx96)
Why not just got F2D? Get the motor you want and also have a very common and available amount of them too. Just a thought.
Old 03-16-2008, 07:26 PM
yoRt's Avatar
Default Re: (96 EX)
how would this engine be wired in? would everythin from the f22 wire up 2 my y7 harness?
Old 03-16-2008, 07:33 PM
yoRt's Avatar
Default Re: (yoRt)
ok did a lil more research and found out the engine is an f23 so it has vtec, which is what i want. how would wiring be from a y7 to an f23 vtec?
Old 03-17-2008, 04:52 AM
yoRt's Avatar
whats better of the h series trannys the h22 or h23?
Old 03-17-2008, 04:55 AM
james p.'s Avatar
Default Re: (yoRt)
I wouldn't do it. Sure it's original and cheap BUT for about the same price you can get a B20B/Z and not have to worry about fab work or aftermarket engine mounts which you will need if you go with the F22.
B20 will be a) easier to install, b) has more aftermarket parts and c) you can add any VTEC B Series head whenever you have the cash.
Old 03-17-2008, 05:36 AM
queda's Avatar
do it. i would love to see how this turns out for you
Old 03-17-2008, 09:27 AM
yoRt's Avatar
Default Re: (queda)
one reason i want to do it is because i feel there is aftermarket support and plenty of it. most of the h22 parts will fit an F. yeah u can find a cheap b20 motor, but then if u want a good tranny, that would prolly be about a grand, and then a vtec head about 500 more. so i would spend 2000 before mounts or axles or anything, id want to get prolly hasport because they are reputable. i could buy and build the f to make more power and pay for everything, and it would still cost less than a b series, plus it would be a good different.
Old 03-17-2008, 12:16 PM
yoRt's Avatar
Default Re: (yoRt)
u can use h22 type s pistons in an f correct? do any of u know of a good place that sells valvetrain components for an f?
Old 03-17-2008, 04:42 PM
awdgsx96's Avatar
Default Re: (yoRt)
Bisimoto for valvetrain, I'm sure there are plenty of others though
Old 03-18-2008, 08:42 AM
yoRt's Avatar
does anybody know where exactly to cut the hole for the shifter cables?
Old 03-26-2008, 06:26 PM
yoRt's Avatar
Default Re: (yoRt)
shifter holes....?anybody know?
Old 03-26-2008, 08:31 PM
superfast666's Avatar
Default Re: (yoRt)
in the fire wall behind the radio but down a little
TheAccordGuy
07-03-2006 07:39 PM
TheAccordGuy
07-03-2006 07:56 AM
EG_Civic_Si
12
09-09-2004 01:04 PM
93blkdelsol
05-03-2004 02:09 PM
hondabadboy
02-18-2002 10:12 AM
Quick Reply: f swap in my soL..
