Exhaust rattling noise
Old 03-20-2003, 12:36 PM
watacivic's Avatar
Default Exhaust rattling noise
something from my exhaust section is making a rattling noise...it only rattles when i rev at like 1500...i was wondering what is causing the problem...thanks
Old 03-20-2003, 12:48 PM
silverEH2's Avatar
Default Re: Exhaust rattling noise (watacivic)
check your heat shield....when i had stock exhaust mine did the same ****. I had a muffler shop cut it off where it was rattling
[Modified by silverEH2, 3:49 PM 3/20/2003]
Old 03-20-2003, 01:10 PM
JasonBlackEJ1's Avatar
Default Re: Exhaust rattling noise (silverEH2)
or it might be ur cat
Old 03-22-2003, 12:57 AM
watacivic's Avatar
Default Re: Exhaust rattling noise (AllShowNoGo)
i dont think the rattling is coming from the cat nor the heat shield...because the noise is coming from the rear of the car
Old 03-22-2003, 04:40 AM
New User
SuperMan19's Avatar
there's a dust/heat shield on top of the muffler itself on a stock exhaust. I had the very same problem, because it rusted loose on 3 corners and was held on to only one, I didn't wanna take off the whole exhaust and remove it so I just went to an auto parts store, muffler repair section, and bought a kit that had a long flat roll of sheet metal with holes in it. There's a screw that comes with the kit that bolts through the holes, to tighten up and hold that dang dust shield in place. It works kinda like a zip tie, but it's metal and uses a screw/nut. Good luck, if that's your case too.
Old 03-22-2003, 06:35 AM
D16Z6racing's Avatar
Default Re: Exhaust rattling noise (SuperMan19)
Is this a stock or aftermarket exhaust?
If aftermarket: Sometimes the fitment sucks and you could have pulled/streched the B Pipe next to the Heat Shield.
If stock: Most likely Catalytic Converter or Muffler replacement time.
Check you hangers too. I've seen hangers break off before and cause rattles. And make sure your rear section (axel back) isn't resting on anything.
Just a few things to start with.
Old 03-22-2003, 06:37 AM
Happyman's Avatar
Default Re: Exhaust rattling noise (D16Z6racing)
If it's your heatshield take a close hanger cut off the hook part and wrap it around the heat shield nice and tight When the noise come back throw another hanger on.
Old 03-22-2003, 06:41 AM
viet's Avatar
Default Re: Exhaust rattling noise (Happyman)
could be your silencer, if you have one. Mine rattles.
Old 03-22-2003, 08:39 AM
mckenzie's Avatar
its probably your muffler hitting the bottom of your car. my eg with honda civic ex b pipe and a 96 hatch muffler makes noise back there.
Old 03-22-2003, 05:26 PM
watacivic's Avatar
Default Re: Exhaust rattling noise (egMee)
i have an aftermarket exhaust with custom 2.25 piping
jonyi27
06-22-2014 11:33 PM
joeli27
04-04-2010 07:51 AM
IntegraMastaz
05-04-2006 06:41 PM
JonGP4
06-30-2003 12:30 AM
Greyout
01-25-2002 04:20 PM
Quick Reply: Exhaust rattling noise
