Exedy cerametallic clutch stage 2
Has anyone had any experience with this clutch? and my car is a daily driver.. should i get a thick disk or thin? thatss the only part im worried bout..
Re: (vlc92189)
EXEDY racing clutches with organic friction materials utilize only premium materials to provide maximum resistance to slippage and burst.
EXEDY full face disc organic clutches can also handle modified engines due to the increased clamp loads.
Drivability with EXEDY organic clutches is similar to that of stock clutches. Pedal efforts will be slightly higher due to the higher clamp loads.
As with all EXEDY clutch discs, EXEDY organic clutches feature high capacity spring center dampers designed to reduce drive train shock and impact.
