Engine wiring harness
Can someone tell me if i can use my stock engine wiring harness and just connect it up to the 2nd gen b16a i have a d16z6 harness are they the same ?
Re: Engine wiring harness (Seven Deuce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seven Deuce »</TD></TR><TR><TD CLASS="quote">Can someone tell me if i can use my stock engine wiring harness and just connect it up to the 2nd gen b16a i have a d16z6 harness are they the same ?</TD></TR></TABLE>
everything should plug in except for the knock sensor. 92-95 civics never came with knock sensors (except b16 del sols).
Moderator
Re: Engine wiring harness (egcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">nope get an obdII - obdI harness</TD></TR></TABLE>
do you have a clue?? that is so much the wrong info!!!
1st Gen - 89-91
2nd Gen - 92 - 95 SIR Also in the Del Sol VTEC
3rd Gen - 99 - 00 SI
Isnt that right?
1st Gen - 89-91
Isnt that right?
Re: Engine wiring harness (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">yes plug n play and add knock sensor unless you want to run chipped ecu that eliminates knock</TD></TR></TABLE>
i had to add a KS wire into my GSR in 92 HB.
personally i would wire it than runnin a chipped ecu.
up to u tho.
up to u tho.
RB_EJ8
11
08-26-2009 09:29 PM
dpine
02-25-2005 04:15 PM
