y8 head
Old 02-22-2008, 06:07 PM
leighton1245's Avatar
Default y8 head
i have a y8 head and z6 block which dizzy shoul di be useing caus ei cant get my car to start with the z6 dizzy
Old 02-22-2008, 07:00 PM
ddd4114's Avatar
Default Re: y8 head (leighton1245)
How did you bolt the z6 dizzy to the y8 head?
A b7 distributor will fit your wiring harness and head, and you can find one for cheap.
Old 02-22-2008, 08:09 PM
Default Re: y8 head (ddd4114)
well all of the feet except on fit but it didnt work cause when i tried to start it it just tried to fire but wouldnt a b7 dizzy will work? and what make and model is that out of? thanks for the help
Old 02-22-2008, 08:14 PM
i have another ? also if i have a z6 block and a y8 head with a y8 cam gear is my timeing going to be off should i switch the cam gears out?
Old 02-22-2008, 08:29 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leighton1245 &raquo;</TD></TR><TR><TD CLASS="quote">well all of the feet except on fit but it didnt work cause when i tried to start it it just tried to fire but wouldnt a b7 dizzy will work?</TD></TR></TABLE>
I have no idea what you're talking about.... please take your time when you type your post so we can understand you.
A b7 distributor can be found on a 92-95 Civic DX/LX or a 93-95 Del Sol S.
I don't know if your timing will be off, but it should not prevent you from starting the car. You can double check you mechanical timing to see if you need another cam sprocket.
Old 02-22-2008, 09:07 PM
hott95ej2's Avatar
use a 92-95 non vtec dizzy,the came gears are the same and dont make a difference unless you didnt set the timing right,the non vtec dizzy bolts right to the y8 head
Old 02-22-2008, 09:09 PM
ddd4114's Avatar
Default Re: y8 head (hott95ej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95ej2 &raquo;</TD></TR><TR><TD CLASS="quote">the came gears are the same and dont make a difference unless you didnt set the timing right</TD></TR></TABLE>
The z6 and y7/y8 cam gears are offset by a half tooth.
SPOON_BeIgHtEeNsEe
05-01-2008 12:46 PM
The Internet Tough Guy
04-17-2006 12:01 PM
skunk2eg
12-26-2005 07:39 AM
gnar kill
11
11-06-2005 09:43 PM
hondacru27
02-12-2004 02:55 PM
Quick Reply: y8 head
