Engine stumbling/stuttering... sounds like its chokin on the gas.... help
Old 12-11-2005, 06:59 AM
drummr6's Avatar
Default Engine stumbling/stuttering... sounds like its chokin on the gas.... help
i gotta 93 1.5L 5 spd civic dx (D15B7). My dad and I just replaced the piston rings and bearings about a week ago. Now, when I drive it, it sounds/feels like its choking on the gas and has a hard time accelerating. Also, when idling, it stumbles and sometimes sounds like its going to stall. I'm also getting very bad vibration. Something with the fuel injectors maybe?
Oh... it also seems to run better while running cold; once it warms up, it runs like complete crap.
Any Ideas?
thanks
Old 12-11-2005, 07:52 AM
SuperSlow's Avatar
Default Re: Engine stumbling/stuttering... sounds like its chokin on the gas.... help (drummr6)
check timing. maybe you are off a tooth.
Old 12-11-2005, 07:58 AM
littleredcivic's Avatar
good when cold, not when hot... check for a vaccum leak.
Old 12-11-2005, 09:39 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: Engine stumbling/stuttering... sounds like its chokin on the gas.... help (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">check timing. maybe you are off a tooth.</TD></TR></TABLE>
Old 12-11-2005, 11:38 AM
accorse07's Avatar
prety sure he off...also may need a valve adjustment
Old 12-11-2005, 12:57 PM
ramos1556's Avatar
Default Re: Engine stumbling/stuttering... sounds like its chokin on the gas.... help (accorse07)
Timming!
Old 12-11-2005, 07:27 PM
drummr6's Avatar
already adjusted valves... gonna check timin again jus to make sure =/
Old 12-15-2005, 07:51 AM
drummr6's Avatar
Default Re: (drummr6)
could the Cat affect the way the cars runnin if its clogged with a bunch of crap? i failed inspection for emissions, and my dad said the cat gets clogged with exhaust junk and that might be affectin the way its runnin. should we jus replace that since we probly have to anyway for emissions?
Old 12-15-2005, 07:53 AM
boostedcivicsmith's Avatar
check the engine timing. you have to use a special tool to measure it and adjust it.
Old 12-15-2005, 10:18 PM
a clogged cat will make the car run like crap. i had a really clogged exhaust system on my subaru wagon before and the car wouldnt even go. somehow, the restriction shot out the back of the car and i took off like a bat out of hell...i was on my way to the dealer...
hmongxcuz
10-16-2008 10:51 AM
davidcrx89
13
11-13-2006 06:24 PM
95excoupe
14
05-27-2006 10:24 AM
Jonovision
09-30-2005 06:48 AM
kaoss_11
10
08-22-2004 06:28 PM
Quick Reply: Engine stumbling/stuttering... sounds like its chokin on the gas.... help
