Engine overheating need help finding problem
Old 06-01-2004, 03:00 PM
scoobyghost's Avatar
Default Engine overheating need help finding problem
Heres the problem. My engine coolant temp gauge will start to rise while at speeds above 55 mph. It doesn't matter if the air conditioning is on or not. The temp will rise fast with the a/c on but if i switch the ac to heat,even without the blower motor on, it will cool down to normal but it will start to rise again if I don't slow down. I replaced the thermostat and the fans seem to be working fine. When my car is at a stand still my engine stays cool, its only at speeds above 55mph or rpms above 2500 or so for an extended period of time. Any suggestions?
Modified by scoobyghost at 6:27 PM 6/1/2004
Old 06-01-2004, 03:39 PM
paybac4223's Avatar
Default Re: Engine overheating need help finding problem (scoobyghost)
bad thermostat?.... or coolant running low
Old 06-01-2004, 04:27 PM
Default Re: Engine overheating need help finding problem (paybac4223)
Sorry but i forgot to add that I just changed my thermostat thinking it was that and the fluid is topped of, I just changed it. Thanks any other suggestions.
Old 06-01-2004, 04:36 PM
EkDave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scoobyghost &raquo;</TD></TR><TR><TD CLASS="quote">Sorry but i forgot to add that I just changed my thermostat thinking it was that and the fluid is topped of, I just changed it. Thanks any other suggestions.</TD></TR></TABLE>
Did you bleed the system? Is your fan coming on?
Old 06-01-2004, 05:10 PM
Default Re: Engine overheating need help finding problem (EkDave)
yes both of my fans are coming on. My next thing to try is a flush but what else could it be?
litterbox
03-16-2009 06:50 AM
Schlag96
07-06-2007 09:17 PM
superstud
10-14-2004 12:44 PM
rdaggett
08-11-2004 12:48 PM
bimrpwr
01-10-2004 01:03 PM
Quick Reply: Engine overheating need help finding problem
