engine noise when cold
Old 12-12-2004, 09:36 PM
xZeler8's Avatar
Default engine noise when cold
okay, jdm b16 in a del sol...when the car is cold and i start it, there is a lot of noise coming from the engine. I can't pin down whether it's from the belt area (tbelt and alternator belts are the only ones on the car) or if it's coming from inside the motor. sounds metallic. when the car is warm the noise is gone...any ideas what it might be? i wouldn't be too concerned except for the fact that it's quite loud. thanks
Old 12-12-2004, 09:40 PM
hayabusa160's Avatar
Default Re: engine noise when cold (xZeler8)
check your valve lash. mines had the same kind of sound
Old 12-12-2004, 09:45 PM
RCautoworks's Avatar
Default Re: engine noise when cold (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">check your valve lash. mines had the same kind of sound</TD></TR></TABLE>
Yep, also it could be your lma, if the noise goes away when vtec engages its more then likely the lma.
What header are you running though, I know a lot of headers will give off sound better causing your engine to sound louder then it was.
Old 12-12-2004, 09:48 PM
xZeler8's Avatar
Default Re: engine noise when cold (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
What header are you running though, I know a lot of headers will give off sound better causing your engine to sound louder then it was.</TD></TR></TABLE>
what do you mean by LMA? and actually, i don't have any vtec engagement right now, that's another problem i'm troubleshooting. i'm just running the jdm header (exhaust manifold) right now. it's only when the car is cold though. how in depth is checking valve lash? is it something i can do at home, or is it going to have to go somewhere? i'm not at home right now, so i don't have access to my manuals etc. thanks again.
Old 12-12-2004, 09:51 PM
head was replaced with type r lma so its not that.
valve lash is easy i did one myself in an hour taking my time
just need the angled feeler guages
Old 12-12-2004, 09:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xZeler8 &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean by LMA? and actually, i don't have any vtec engagement right now, that's another problem i'm troubleshooting. i'm just running the jdm header (exhaust manifold) right now. it's only when the car is cold though. how in depth is checking valve lash? is it something i can do at home, or is it going to have to go somewhere? i'm not at home right now, so i don't have access to my manuals etc. thanks again.</TD></TR></TABLE>
Check cspeedracing.com for the valve adjustment
And the lma's are basically a spring type device that keeps your middle vtec rocker arm from floppy around when vtec is not engaged.
Old 12-15-2004, 12:06 AM
xZeler8's Avatar
thanks for the info guys
Old 12-21-2004, 04:07 PM
xZeler8's Avatar
just for search reference, the problem ended up being a dent in the oil pan right underneath the oil pickup...was getting a max oil press of 20 psi and everything else checked out good...this was also obviously the cause of my vtec never engaging...
HondaScott
Honda Civic (2001 - 2005)
06-13-2006 04:05 AM
Silvteg95
08-01-2005 11:28 AM
RedDC5
10
04-25-2005 05:33 PM
obsidianG35
09-04-2003 08:55 AM
pimpinainteasy
08-04-2003 02:51 PM
Quick Reply: engine noise when cold
