engine light on
Old 09-20-2004, 10:15 AM
slosol's Avatar
Default engine light on
my check engine light is on for no reason its reading knock sensor but vtec is working how do you reset the ecu from coming on i have a b18c1
Old 09-20-2004, 10:44 AM
Luserkid's Avatar
Default Re: engine light on (slosol)
disconnect the batt for 10 seconds.
Old 09-20-2004, 10:49 AM
mikehawkBUiLT's Avatar
Default Re: engine light on (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the batt for 10 seconds. </TD></TR></TABLE>
wrong. its the 10amp fuse under the main fuse block under the hood. leave in unpluged for 10 seconds and the ecu will reset
Old 09-20-2004, 10:50 AM
eK9aT10pSi's Avatar
Default Re: engine light on (EJcoupe)
its acutally a 7.5amp fuse on the back row underhood fuse box
Old 09-20-2004, 10:51 AM
Madspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">
wrong. its the 10amp fuse under the main fuse block under the hood. leave in unpluged for 10 seconds and the ecu will reset </TD></TR></TABLE>
i think its a 7.5 but anyway.....
also unplug the hazard fuse under the hood....not sure if this is a "wives tale" or not but it always works for me.....
Old 09-20-2004, 11:00 AM
Luserkid's Avatar
No not wrong, you could disconnect the neg. batt for 10 seconds and that resets everything in the car. You unplug the fuse if you care about radio, and such.
Both ways are correct.
Old 09-20-2004, 11:28 AM
slosol's Avatar
thanks for the help guys
dylokjai
12-20-2006 11:12 AM
Fat Chick Magnet
09-01-2006 05:39 PM
luvinmyGSR
06-12-2006 10:44 PM
brandons 95ls
03-12-2006 08:26 AM
Layziebtnh055
13
04-20-2004 05:38 AM
Quick Reply: engine light on
