Engine Coolant Temp (ECT) sensor questions
#27
Re: Engine Coolant Temp (ECT) sensor questions
#29
i have a question towards the cooling problems. my gauge cluster says my car is running at 210 degrees. like a idiot i figured there would be pressure there for the cap should spray coolant out. i put a towel over it and opened it. there was no pressure and the coolant should have been boiling but it wasnt. is there a reason my gauge could be giving me the wrong reading from the signal sensor
#30
#31
i had a buddy splice a gauge into the signal wire that comes from the signal sensor to the cluster. it says the car is running hot but its not even hot enough to open the t stat. i know the gauge on the cluster is shot. im just lost on what to check now
#32
Can somebody upload a picture of the thermostat housing for a 95 civic ex please? I'm trying to do all of this crap you guys are talking about but I can't seem to find the location... thanks.
#33
#35
ok i have followed all this in to a t and replaced all sensor except under the distributor and still gauge works but fan still not kick on should i replace that sensor too? i also replaced relay just incase and jumped the pins to test fan and the fan runs but when car gts hot it not kick on help please lol
#36
#37
#38
hi ron how are you?i have a problem with my coolinng fans not coming on. the a/c fan does come on after the engine is off at times but not the radiator fan on the drivers side.i check everything to the temperature sensor,burp the system everything ang still the radiator fan dont turn on.you think it might be the timer underneath the steearing wheel?and what does the sensor under neeath the dizzy is for?
#40
#41
mon2mon2
01-17-2022 06:49 PM
fleabag
12-19-2011 01:33 PM
arkomandos
11-15-2010 09:15 PM
