suspension question ??
Old 10-03-2004, 12:49 PM
killaj12's Avatar
Default suspension question ??
i was wondering how to adjust the ride height on koni yellow shocks/struts ..
i have a 00 si with eibach sportlines and koni yellows, and right now the ride height is too low .. i live in NY which has crazy potholes etc ..
i wanted to raise the height around 3/4 of an inch .. is that possible by adjusting the shocks ? and how much would it cost to do it professionally ?
or should i just reinstall the stock springs ?
pleaseeee helpppp, i cant drive this thing while its this low !!
Old 10-03-2004, 01:36 PM
sol_dwn's Avatar
Default Re: suspension question ?? (killaj12)
you should reinstall the stock springs and then get your self a good set of coil overs. the coil overs are what alow you to adjust the height of your ride.
Old 10-03-2004, 01:50 PM
Kendall's Avatar
You can't adjust the ride height via the shocks. You'll have to invest in different springs or perhaps some coilovers. Ground Control makes good affordable sleeve type coilovers.
TwitchDa9
03-22-2011 05:33 AM
TigerLy
06-17-2008 01:07 AM
napalm588
Suspension & Brakes
08-22-2007 01:37 AM
PEARLWHITE
02-06-2003 05:06 PM
Integra187
04-09-2002 06:32 PM
Quick Reply: suspension question ??
